Thought it was time to upgrade to a Weller
Icky Projects
Re: Icky Projects
Finally my old Maplin Soldering Iron station has given up. Not mine in the picture
Re: Icky Projects
My own Maplin Iron (Not as fancy as yours) is now on duty in France after an iron replacement when the plastics failed.Icky wrote: Tue Apr 28, 2026 10:02 am Finally my old Maplin Soldering Iron station has given up. Not mine in the picture
Surely fixing your old one would be a good little project
Re: Icky Projects
I do intend to fix it so I can use else where from my main station location, however time is the issue.rubber_jonnie wrote: Tue Apr 28, 2026 10:33 am My own Maplin Iron (Not as fancy as yours) is now on duty in France after an iron replacement when the plastics failed.
Surely fixing your old one would be a good little project![]()
Re: Icky Projects
I hear ya.Icky wrote: Tue Apr 28, 2026 10:35 amI do intend to fix it so I can use else where from my main station location, however time is the issue.rubber_jonnie wrote: Tue Apr 28, 2026 10:33 am My own Maplin Iron (Not as fancy as yours) is now on duty in France after an iron replacement when the plastics failed.
