Did you try using the "c2p_akiko2" routine?alenppc wrote: Thu Mar 28, 2019 12:42 amIt's on Aminet8 Bit Dreams wrote: Wed Mar 27, 2019 11:18 pm is there any place to download Doom Attack from? can't find it on EAB...![]()
The problem though is finding full version compatible wad files for DOOM1. If anyone can help let me know.
A few findings from tonight: installing MMULib v46 from aminet fixes the akiko caching issue. So effectively this forces the 68030.library to be loaded which fixes the 030 data cache bug.
I was finally able to initialize an akiko screenmode but it only worked once out of 10 times I tried to run it (firmware v1) haven't tried v2 yet.
Some stats
Doom shareware wad run as "doomattack.020 -timedemo demo1 -forcedemo" with 020_optimized c2p gives me 7.54 FPS (firmware v1) and 8.83 fps (v2)
Remember the time demo renders every frame so it's a lot slower than actual gameplay.
Be interesting to see if the c2p test from this thread could be tried:
http://eab.abime.net/showpost.php?p=131 ... stcount=63
...and a comparison with the TF328!
