Got and flashed it right away!terriblefire wrote: Tue Mar 26, 2019 9:22 pmThere is a newer one AlenPPC can give you.nibiru wrote: Tue Mar 26, 2019 9:20 pm Thanks everyone.
Should I try to flash the beta in the other thread then? I remember flashing the TF328 with my RaspPi, can I do the same?
Here are my findings with the V2 firmware:
• Sysinfo: speed boost from 1.63 vs A3000 to 1.97, this one seems nice!
• Fusion: fails to detect the Akiko at times, and when it runs the screen is mangled again, this time it doesn't matter whether the data cache is on or off
• Wing Commander: runs, but *a lot* slower than with the V1 firmware. I was really surprised by how fast it was going (compared to the CPU only version), meaning that Akiko is not super-crappy after all
• DoomAttack (aka Doom CD32) fails to initialise the Akiko C2P, resulting in an RTG version being used, that is terribly slow (my guess is that the OS fails with Akiko too, so it falls back to CPU for WritePixelArray8(). With the V1 firmware Doom was somewhat playable with the default screen size (and 1x1 pixels)
Hope this helps... I think I'll go back to V1 for now.
Cheers.
EDIT: I've also noticed that SysInfo reported the MMU as inactive earlier, while now it says: "In use". Not sure what are the implications, and if it would help to install a 68030.library...
