Redhawk668's TF534 build.
kludge
Re: Redhawk668's TF534 build.
Crap, I feel for you. :(
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
My lack of focus:
8 Bit Dreams
- Moderator Team
Don't give up!
Choose lower temperature next time - 320-330° should be really enough...
redhawk668
So, removed most of the parts of my failed TF534 board and soldered them on a new board. Went allright, only the large CPLD did not come off properly :(, had to order a new one + passives, resistors, etc.
8 Bit Dreams
- Moderator Team
You need a preheater to remove parts from a 4-layer board, because inner layers obsorb heat, increase temperature will destroy cpld..
A cheap 17€ smartphone display separator will do the job
Regards,
Viktor
Regards,
Viktor
- Admin sponsor
where are you seeing a 17€ preheater?
8 Bit Dreams
- Moderator Team
have bought one on www.aliexpress.com
Something like this will do the job:
https://de.aliexpress.com/item/LCD-Heiz ... e7d99ff-34
pay 35€, and You will get one with vacuum pump that holds cell phone in place, so You can separate broken glass easily :idea:
redhawk668
I am getting back in this project, I've put it on hold for a while, but with new PCB's and some new components I will build a new one. I will use the 68030/68882 combo from my TF530. This time it will result in a working TF534.
Users browsing this forum: CCBot and 24 guests
