LMAO, good luck with that. BTW, just fixed it, turned out to be a dodgy 68882 :shock:
PhilC's TF534 build x 2
Re: PhilC's TF534 build x 2
- Admin sponsor
You'll need to get ISE working.. and a programmer.. this has been the limiting factor on your terriblefire.exxos wrote: 27 May 2019 16:50
Sweet. Then I can rip apart TF's firmware and re-write it all, all in a language I never used before 8-) :lol:
I need to reinstall the ISE again.. no idea if I need any particular version or not ? I did have it working a while ago as I flashed my CT60 ages ago.terriblefire wrote: 27 May 2019 17:31 You'll need to get ISE working.. and a programmer.. this has been the limiting factor on your terriblefire.
- Admin sponsor
I have a Virtualbox VM with 10.1 and 14.7 on it. I dont use the IDE at all. just makefiles.exxos wrote: 27 May 2019 17:41I need to reinstall the ISE again.. no idea if I need any particular version or not ? I did have it working a while ago as I flashed my CT60 ages ago.terriblefire wrote: 27 May 2019 17:31 You'll need to get ISE working.. and a programmer.. this has been the limiting factor on your terriblefire.
Was that the thing which screwed up my internet when I installed it ? I had to uninstall the IDE a while ago, it was soaking up 30GB on my drive, I only have 6GB left on my C: drive, so would have to get installed on my old brick drive :roll:terriblefire wrote: 27 May 2019 18:19 I have a Virtualbox VM with 10.1 and 14.7 on it. I dont use the IDE at all. just makefiles.
- Admin sponsor
Yes .. the install sizes are comedy.exxos wrote: 27 May 2019 18:21Was that the thing which screwed up my internet when I installed it ? I had to uninstall the IDE a while ago, it was soaking up 30GB on my drive, I only have 6GB left on my C: drive, so would have to get installed on my old brick drive :roll:terriblefire wrote: 27 May 2019 18:19 I have a Virtualbox VM with 10.1 and 14.7 on it. I dont use the IDE at all. just makefiles.
- Admin sponsor
What is the speed of the CPU?
The oscillator was set at 33mhz. I will order some 50s at some point
50mhz oscillators ordered, so will fit those and then see how I get on over the weekend.
Just re-flashed one of my TF534s from the ST to the Amiga.
Everything looks good so far and tomorrow I'll get the rest of the Amiga stuff together.
A couple of questions for you Amiga TF Gurus.
1. My 500+ has Kickstart 2, do I need to upgrade it to 3.1?
2. Is there any specific Diagrom version to use? I'm planning to burn it to a 27C400 but not burnt any Amiga Roms yet.
3. Will I need to get any specific drivers for the IDE interface, or will this work out of the box with KS3.1? / KS2.04?
4. Will I need to disable the MMU etc for it to work?
5. Other than youtube, is there any written instructions for setting up a TF card on an Amiga. I'm more of a reader than a watcher for learning stuff.
6. Is 50mhz going to be unreliable with Alliance memory?
Apologies if these are repeats of questions already asked. Just getting my TF Amiga fix.
Users browsing this forum: CCBot and 3 guests
