kludge’s TF534 build
Re: kludge’s TF534 build
I just added an open board view file for the TF534 to the github page.
https://github.com/terriblefire/tf534
Note by default it opens on the bottom of the board.
kludge
Post by kludge »
terriblefire wrote: 28 Mar 2019 14:52 I just added an open board view file for the TF534 to the github page.
Nice! Thank you!
Got this today. Might also help. Maybe.
My lack of focus:
kludge
Post by kludge »
Beeped my way throug the CPLDs, RAM, buffers and resistor networks, and can’t find any shorts.
Next I will try to work my way through OBV to see if somethings not connected right. But that’s for another day.
My lack of focus:
try this firmware
https://www.dropbox.com/s/icxg3d8a2rbov ... g.zip?dl=0
I havent tested it but it should make the TF534 think the RAM is already configured so the OS will not try to allocate it to the system pool.
Then you should be able to diagnose if the issue is IDE or not... and finally use
http://aminet.net/package/util/cli/AddMem
do
ADDMEM START 40000000 TO 40400000 PRI -100
this will make the fastram low priority and not get code run in there . You should then be able to load systest from a cli.
kludge
Post by kludge »
terriblefire wrote: 29 Mar 2019 07:57
Perfect, thanks! The wife will have to do without my company in front of the TV tonight as well :D
My lack of focus:
kludge
Post by kludge »
kludge wrote: 29 Mar 2019 09:04 Perfect, thanks! The wife will have to do without my company in front of the TV tonight as well :D
That didn't work out as planned. Wish me luck tomorrow!
My lack of focus:
Justme14
Post by Justme14 »
terriblefire wrote: 29 Mar 2019 07:57 try this firmware
do
Hi TF,
This firmware now works for me 3.1 boots with IDE , no issues :yay2:
Next step with addmem START 40000000 TO 40400000 PRI -100, @ the moment I press enter ,and gives a softwarefailuer and reboots.
Will try to resolder/reflow all the ram chips..
Thanks a lot for this nonautoconfig firmware ...,Very helpfull
No Problem,
I sometimes forget that I do this alot when bring up boards... hack firmwares to give me info.
Justme14
Post by Justme14 »
kludge wrote: 28 Mar 2019 15:16
Nice! Thank you!
Nice Station you have there,seems you have big plans ahead ;) !
kludge
Post by kludge »
Justme14 wrote: 29 Mar 2019 22:14 Nice Station you have there,seems you have big plans ahead ;) !
I needed a hot air station and thought that I could use an extra soldering station as well, so I bought a combo :)
My lack of focus:
Return to “TF534 (OBSOLETE)”
Users browsing this forum: CCBot and 56 guests
