kludge’s TF534 build
8 Bit Dreams
Re: kludge’s TF534 build
Post by 8 Bit Dreams »
This may be a crap CPU, have similar issues with at least 15x 33Mhz CPUs ive bought recently.
Try to swap it out for known good one :roll:
kludge
Post by kludge »
8 Bit Dreams wrote: Fri Jun 28, 2019 12:56 pm This may be a crap CPU, have similar issues with at least 15x 33Mhz CPUs ive bought recently.
I’ve tried with one Motorola and one Freescale, both EC variants rated for 40 MHz. Guess I’ll try swapping in the Motorola that sits in my working TF534 (also EC/40 MHz) to see if that works.
I REALLY hope that it isn’t the CPU
My lack of focus:
kludge
Post by kludge »
The Freescale CPU works fine at 50 MHz in the other TF534, so that wasn’t it. Phew.
I’ll reflow the bus CPLD later to see if I have an intermittent connection somewhere.
My lack of focus:
chue
Post by chue »
Are you using a used CPU socket? I've had glitches with dirty / loose socket pin receptacles. To test this I put my CPU in at a slight angle so that the CPU pins make good contact. After verifying that it worked, I sprayed the socket with contact cleaner and the glitches went away.
kludge
Post by kludge »
chue wrote: Sat Jun 29, 2019 12:32 am Are you using a used CPU socket? I've had glitches with dirty / loose socket pin receptacles. To test this I put my CPU in at a slight angle so that the CPU pins make good contact. After verifying that it worked, I sprayed the socket with contact cleaner and the glitches went away.
I'm making my own out of brand new female headers. I've cut a jig for it in a CNC router and they seem solid enough. I've replaced the CPU in the first one multiple times without any glitches, so I don't think that's it.
My lack of focus:
kludge
Post by kludge »
Ok. An update more than a year later 😄
A year ago I started replacing the CPU socket, and while doing so I ripped some traces. Because I’m an idiot. And my desoldering gun had a bad tip.
So I shelved the entire thing and haven’t looked at it since. Well. I bought a PCB from @8 Bit Dreams. Then I shelved it.
Until today. Today I started transplanting the CPLDs, RAM, buffer and stuff to the new board. I think it went quite well.
We’ll see in a couple of days when I’ve got time to continue :)
My lack of focus:
Danoo
Post by Danoo »
kludge wrote: Mon Sep 14, 2020 11:02 pm Ok. An update more than a year later 😄
Looks like your project and time management is on par with my own, I have more than a dozen Amiga hardware projects on the go ATM and I just keep buying more. :stars:
(eg. 3 x A2000 MB to repair, 2 x A1200 Re-Amiga builds, 4000ATX build, A1200 desktop build, CD32 repair and a assortment of open source PCBs to build) :dizzy:
I finally found the time to complete a couple of TF536 in the last few weeks so I am kicking some goals occasionally :roll:
I did find the 534 was a little more tedious to build than the 536
Good luck with the finishing the TF534,
Life is really simple, but we insist on making it complicated - Confucius
kludge
Post by kludge »
Danoo wrote: Tue Sep 15, 2020 10:45 am Looks like your project and time management is on par with my own, I have more than a dozen Amiga hardware projects on the go ATM and I just keep buying more. :stars:
I only work on hobby projects when I want to, so if I get stuck or mad I just put them away for a while while I work on other stuff :)
Yeah... Rub it in with the 536 will ya. I probably missed my chance :D
My lack of focus:
Return to “TF534 (OBSOLETE)”
