kludge’s TF534 build
8 Bit Dreams
Re: kludge’s TF534 build
Post by 8 Bit Dreams »
You need to start at the other end. One of my TF534 IDE's also stopped to work - turned out it was bad CF reader. It worked fine, but then stopped for an unknown reason... 0603 resistors are 1k on all my boards
Check CF Card》check CF reader》check ide ribbon, when that's all fine - then switch to the board.
If that all doesn't help - let me know, will send you a replacement pcb, have Your addresses already
Will also include RNs
kludge
Post by kludge »
8 Bit Dreams wrote: 12 Jun 2019 08:18 You need to start at the other end. One of my TF534 IDE's also stopped to work turned out it was bad CF reader. It worked fine, but then stopped for unknown reason... 0603 resistors are 1k on all my boards
I don't believe that the CF adapter is bad as it works on Kickstart 3.1.4 and works absolutely fine in my A600. I have more CF adapters incoming, however, so I'll try another one when I get them. The IDE cable is brand new, and I have tested a couple of them.
It could be that 1kOhm is right on the edge and something else differs with my boards and yours making 1k not work on mine. Maybe? It's easy enough to swap them out anyway :)
My lack of focus:
8 Bit Dreams
asy to swap...if You use pin headers..
kludge
Post by kludge »
8 Bit Dreams wrote: 12 Jun 2019 08:27 asy to swap...if You use pin headers..
Yeah, I can imagine it would be quite tight if using a "real" connector :)
8 Bit Dreams wrote: 12 Jun 2019 08:18 If that all doesn't help - let me know, will send you a replacement pcb, have Your addresses already
I have two more TF534 PCB's waiting to be built, so I'm good. I also have a bunch of 1k RN's. But thank you very much for offering!
My lack of focus:
kludge
Post by kludge »
R1 and R2 has been changed to 2.2 kOhm resistors. That made no difference.
Tried booting on the 3.1 Install floppy, and at first didn't see the CF card. Ran HDToolBox, and while freezing for a bit when "checking scsi.device address 0 unit 0", the CF card was detected and icons appeared. I think 3.1.4 has the same problem with my card, but uses a pointier stick when probing for devices during boot up. I'll link in a video of this.
Haven't got my shipment of CF adapters yet, so I can't check that. I'll try reprogramming the CPLD's if I did something stupid or used some weird release. I don't think that's the case, but it's probably all I can do for now.
Cheers!
My lack of focus:
8 Bit Dreams
Hmmmm... i would say Your CF is screwed up..
did You tried other one already?
kludge
Post by kludge »
8 Bit Dreams wrote: 12 Jun 2019 23:11 Hmmmm... i would say Your CF is screwed up..
I’ve tried like 8 different CF cards earlier, and none were detected by DiagROM. I didn’t try any other cards tonight, though.
My lack of focus:
chue
Post by chue »
Try the CF card in Winuae with KS 3.1 to see if it boots.
kludge
Post by kludge »
chue wrote: 13 Jun 2019 02:56 Try the CF card in Winuae with KS 3.1 to see if it boots.
It was created in Winuae with KS 3.1, so at least it did work :)
My lack of focus:
kludge
Post by kludge »
8 Bit Dreams wrote: 12 Jun 2019 08:18 [...]
check CF reader
I hate you. Also, I love you.
Has anyone figured what makes different IDE controllers liking one CF adapter more than another one? It’s just a stupid passive adapter. Oh well. Seems fixed now.
Do you know if it would work with either a 0.1uF 0603 or 10uF 1206 for C18? I forgot to order a 0.1uF 1206... :)
My lack of focus:
Return to “TF534 (OBSOLETE)”
Users browsing this forum: CCBot and 8 guests
