kludge’s TF534 build
dalek
Re: kludge’s TF534 build
Post by dalek »
I'd check your solder joints on the IDE header pins - I've had cases where the solder mask was a bit iffy and you get a short to ground with some of the through holes. I'm guessing you've already checked over the cplds a hundred times? Why not post a close-up pic of both sides of the board - maybe someone can spot something...
kludge
Post by kludge »
So, I've reflowed the RAM CPLD, and now it's somewhat working. KS 3.1.4 detects the CF card and boots from it happily (albeit with quite a long delay on power up, ~48 seconds from power up until I get to the kickstart menu when holding down both mouse buttons). The weird thing is that neither KS 2.05, 3.1 nor DiagROM detects the CF card. I might have a bad solder joint somewhere else, but this is really weird. Crazy fast, though :D
Image 11.JPG (277.81 KiB) Viewed 7347 times
My lack of focus:
kludge
Post by kludge »
dalek wrote: Tue May 28, 2019 1:06 am I'd check your solder joints on the IDE header pins - I've had cases where the solder mask was a bit iffy and you get a short to ground with some of the through holes. I'm guessing you've already checked over the cplds a hundred times? Why not post a close-up pic of both sides of the board - maybe someone can spot something...
Yeah, I might post some close ups if reflowing the BUS CPLD doesn't work, but I've looked REALLY close and can't see any bridges anywhere, so the only thing I can think of is that there's some pin somewhere that hasn't got a good enough connection.
My lack of focus:
Sounds like the resistors maybe a bit squirly. 2K or 1K?
kludge
Post by kludge »
terriblefire wrote: Tue Jun 11, 2019 8:49 pm Sounds like the resistors maybe a bit squirly. 2K or 1K?
The resistors and resistor networks are 1K :oops:
But it seems to work fine with 1K resistors according to... Was it 8 Bit Dreams that used them?
My lack of focus:
kludge wrote: Tue Jun 11, 2019 8:51 pm
i use 2K2s
kludge
Post by kludge »
terriblefire wrote: Tue Jun 11, 2019 8:53 pm i use 2K2s
Yeah, I know. And I know the BOM says 2K2, but I already had a stash of 1K's and the import fees would be freakishly high for just a resistor order. And I'm sure one of the builders said that they were using them.
Oh well... Might try to swap them out.
Are the values of the resistors and resistor networks equally important? I can find SMD resistors easily here in Sweden (I might even have some in a box somewhere), but the 2K2 RN's are much harder to find with reasonable shipping and import fees.
My lack of focus:
chue
Post by chue »
I used 1K resistor networks in my build. As for the other resistors, I used 2.2K and 47K, per the BOM.
kludge
Post by kludge »
chue wrote: Tue Jun 11, 2019 11:48 pm I used 1K resistor networks in my build. As for the other resistors, I used 2.2K and 47K, per the BOM.
I might try to swap out the 1K 0603’s for 2K2’s and see if it makes a difference.
My lack of focus:
kludge
Post by kludge »
kludge wrote: Tue Jun 11, 2019 8:59 pm
Answering my own own question after opening up the schematics: The RN's are probably fine as they are. :)
My lack of focus:
Return to “TF534 (OBSOLETE)”
