Yep, that breaks it too. Want a job in the Destruction team?
:o)
:o)
Flashy Clock - Yet another DEV board
Re: Flashy Clock - Yet another DEV board
Does this firmware work and you done the mods ?
https://www.exxosforum.co.uk/forum/viewt ... =40#p24339
You are also erasing the chip before programming ?
Yes done the mods and yes erasing first. Will try again with the latest just in case.
STill didn't boot with either 68000 or 68010. Screen stays at 60hz.
You mean the FC3A-1 firmware doesn't boot ? If that's the case, something is wrong somewhere as myself and Icky are using that version just fine.
The FC3A-1 works fine, it's the two FC4 ones that don't.
:shrug: I will try and put my board back on to test it, but won't be until Monday now.
No rush st all. It's you guys I'm here to help, not the other way round
When you are ready you are ready. For now, I will try and break it other ways, ie 68010, fitting IDE on top, Pak etc etc.
Its a shame the 68010 doesn't run faster, not even 16MHz :(PhilC wrote: 26 Jul 2019 17:29 When you are ready you are ready. For now, I will try and break it other ways, ie 68010, fitting IDE on top, Pak etc etc.
Never had one until today. I can always try one of your c1 5 boosters on it?
