Flashy Clock - Yet another DEV board
Re: Flashy Clock - Yet another DEV board
Hi Guys,
Sorry, been a bit slow with this but just done the patch and it boots fine to all 4 flash roms.
BTW, was I supposed to leave the TOS1.02 roms fitted to the motherboard?
PhilC wrote: Fri Jul 26, 2019 2:30 pm Hi Guys,
:bravo:
If you have the older firmware and the wire link on the board, then you have to take out the MB ROM's else they will conflict with the flash ROM's.
With the latest firmware and mod icky mentioned the other day, the MB ROM's can be left in the MB now.
Ok Cool, will put them back in and try again
Just noticed something. This STFM has a glitter installed but now when I select it the menus turn black. disabling them again puts it back to normal.
Was going to GB it
PhilC wrote: Fri Jul 26, 2019 3:10 pm Just noticed something. This STFM has a glitter installed but now when I select it the menus turn black. disabling them again puts it back to normal.
Was going to GB it
Oh yep, that reminds me, its not been fixed to work with the blitter yet.. I think... Have you got the new firmware programed in (assume so)
OH forgot to say.. "AGAIN with the breaking things!!" :lol:
Try this firmware see if it helps...
FC4.zip
(3.99 KiB) Downloaded 153 times
Ok, will try that in a mo, just tried to break it another way but it's still working.
Can you see what I did yet?
:lol:
PhilC wrote: Fri Jul 26, 2019 3:32 pm Ok, will try that in a mo, just tried to break it another way but it's still working.
Can you see what I dud yet?
:lol:
Yep.. Its not actually crashing or anything.. its because the blitter can't access ROM.. so it reads back "11111111" all the time, hence you get blank/black squares all over the place...
https://www.exxosforum.co.uk/forum/viewt ... 370#p17621
That's fair enough, similar problem to the Paks then.
Didnt boot with V4, had to reload the previous.
I'm just amused at the fact that the 010 works fine
Try this one...
FC4a.zip
(4.03 KiB) Downloaded 144 times
Return to “PHOENIX ZONE”
