Don't seem to be having much luck with the 11 boards with the genuine PLDs. So far 4 boards have passed tests and 4 boards have failed
Mostly they seem to be failing on flash programming..
- IMG_4751.JPG (62.16 KiB) Viewed 999 times
Two of the boards my flashy software claims the RTC is timing out. Whether this be bad soldering or bad PCB or bad chips, it would take a colossal amount of time to diagnose it all, which just isn't worth the time and effort. I already had to fix and fault find TRUDIE. So I know PCBWAY soldering is bad, and some boards I gave up trying to fix. So assume the PCB itself (or chips) are bad.
The problem is with the RAM and RTC chip costing like £50 now, that's going to total like £1,500 in chips alone. I think getting them built again from scratch would probably be the best solution. Of course I cannot really write off that much either. So sent a plea to my UK assembly place to see if they would consider recycling some chips and assembling new boards from scratch.
Is a bit of a crappy situation, because it's either writing off all the faulty boards and forgetting about it, or spending even more time and money trying to recycle those parts where I would not get my money back anyway. It's basically a lose lose situation.
The RAM could be left off a new batch. That would reduce cost in not having to deal with the RAM chip. But would ultimately cost more because of the new batch being made. So is difficult to really tell if they would work out any cheaper in not fitting the RAM on the new batch anyway.
Will just have to see what demand is like for flashy clock over the year. If the boards in stock don't sell, then I will just have to "write off" the rest of the stock and chalk it up to more experience as to not use China for anything anymore !
Flashy is listed now in the store, but no actual stock yet. But people can add it to their baskets meanwhile.
https://www.exxosforum.co.uk/atari/store2/#0314
I have also done a quick page to explain setup etc
https://www.exxosforum.co.uk/atari/last ... /index.htm
