Just think of it this way Exxos, 140x5=700 700/60=11.4 additional hours!!!! :mrgreen: :mrgreen: :mrgreen:
It's not much in the grand scheme of things but every minute helps!!!
:o)
:o)
Flashy Clock - Yet another DEV board
PaulJ
PaulJ
Re: Flashy Clock - Yet another DEV board
Phil, scarped your last warts off. I took out the Exxos time expansion since he has already extended a day to 140 hrs. :)
Finally got the v3 to boot and work today with newly written firmware in it. Main issue was around the dreaded header socket contacts.
So what's new in the v3:
- Smaller lower profile design
- FlashROM select to be done by software not jumpers - don't want to keep opening the case to change things
- Addition of IO lines to use with the future ALT-RAM board Exxos is working on
Hi guys, sorry, not had as much time as I would like at the minute with RL getting in the way.PaulJ wrote: 03 Sep 2019 01:48 Phil, scarped your last warts off. I took out the Exxos time expansion since he has already extended a day to 140 hrs. :) CLOCK.TTP.zip
Will get back to the breaking soon.
PaulJ
Received the Lightning_ST today and installed it in the mega4 I use to work on software for the clock board. THING WORKS GREAT!! Now have an Ethernet connection to the MSTE and the MEGA 4 not to mention usb storage on both. I can finally use bbedit on the mac to edit files from the ST. Was really a pain transferring files for the mega via the MSTE to the mac. Only thing remaining is to check out its IDE interface. See photo... the Lightning ST is hiding under the clock board. :) :) :)
Looks good Paul, may check one out too at some point.
Gotta get your stacking fix.
PaulJ
Phil, you know as well as I do if you spend any time on this forum its inevitable that you will catch the "ExxosIcky" stacking contagion. I haven't heard of a cure so I expect it will just get worse. :mrgreen: :mrgreen: :mrgreen:
I'd best buy some longer screws to hold my case together then Paul :lol:
Maybe Icky can do a ST case revision which is 15" high :D :D
PaulJ
Well its not like he doesn't have a 3d printer large enough. He could print a house to put the 15" high ST in!!
