Flashy Clock - Yet another DEV board
PaulJ
Re: Flashy Clock - Yet another DEV board
Post by PaulJ »
Phil, I may have found your issue. I assume your running on a vanilla ST..
These files supersede all others.
Archive.zip
Paul, yes I'm booting with a blank disk and just the clock files on it.
The STFM has a glitter and 1mb. Not tried this one in a Mega yet.
PaulJ
Post by PaulJ »
Try the the new archive most recently posted. I believe it may fix your issues. Forget the ones I messaged ya.
Thanks Paul, will be tomorrow but will definitely try it.
PaulJ
Post by PaulJ »
Pretty sure it will work for ya this time. Can't wait to get the new lighting card, such a pain in the arse to move files from the mega to the mac. Have to move to the MSTE and then to the mac via its lighting board. I could move the flash card right to the mac but osx loads it up with trash. I do use USClean which usually gets rid of the trash but sometimes some slips through. Any how Phil I believe this one should work for ya. Also its noticeably faster. :) :) :) :)
Got it working finally, does this count for a slight issue?
And if I press any letter it quits the main menu
PaulJ
Post by PaulJ »
I don't know Phil, when you select option 8 it shows date and time as you show, press any hey and it goes back to the main menu. :)
I dunno how mine got to 62 mins past tho
PaulJ
Post by PaulJ »
PhilC wrote: 02 Sep 2019 06:35 I dunno how mine got to 62 mins past tho
Phil, what your observation has uncovered is a special feature to lengthen the day for Exxos and Icky. Since they have so many irons in the fire I have added 5 seconds to every minute so they can get more done every hour.. :mrgreen: :mrgreen: :mrgreen:
If you don't like the extended time I'll see if I can turn it off. And I'll fix the main menu exit. :lol: :lol: :lol:
I already invented the 140 hour day, still not helping :(
https://www.exxosforum.co.uk/forum/viewt ... 547#p23547
Return to “PHOENIX ZONE”
