:o)
:o)
Selling 2x ready built TF520 Cards
utri007
Re: Selling 2x ready built TF520 Cards
I take one, pm for details
czietz
Out of curiosity @8 Bit Dreams: Which firmware did you put on the TF520 so that they run in an Atari? I found none of the publicly available firmware versions to run satisfactorily in my ST.
8 Bit Dreams
- Moderator Team
have programmed the latest firmware available thru Stephen Leary,
He backported it while he was working on TF534,
im pretty sure this firmware was uploaded on Github
sending PM
czietz
Would you mind sending me the link (or attach the file here or send it via PM)? Thank you in advance.8 Bit Dreams wrote: 04 Dec 2019 19:23 have programmed the latest firmware available thru Stephen Leary,
As mentioned, I've found multiple versions in multiple places (incl. Github) and none would run really stable on the ST.
frank.lukas
I use mine on a Atari ST and it is stable under TOS 2.06. Sometimes there are 2 bombs at boot or the computer hangs. But very rarely. I have a lot of stuff working with the TF520. 1040ST Mainboard -> Lightning ST -> PuPla/2 -> Panther/2 with TSENG ET4/W32i and a NE2000 Network card.
What firmware is exactly on the TF520 ?
8 Bit Dreams
- Moderator Team
Had no time to check exact fw build - have a separate computer for these purposes, all firmwares are stored there,
will upload fw i used here..
guus.assmann
Hello,
Is there a board available from the ones you had left?
I'd be interested in one.
BR/
Guus
BR/
Guus
frank.lukas
thanks8 Bit Dreams wrote: 06 Dec 2019 13:36 Had no time to check exact fw build - have a separate computer for these purposes, all firmwares are stored there,
I will wait ...
8 Bit Dreams
- Moderator Team
Yes, i do have one card left,guus.assmann wrote: 06 Dec 2019 16:55 Hello,
BR/
Guus
will send You PM now
Also have some PCBs (green) if someone is interested
