TT Boot Logo
alienkidmj12
Re: TT Boot Logo
Post by alienkidmj12 »
really nice logo that, wouldnt mind it myself, i take it you need to flash a new rom ?
Re: TT Boot Logo
Atarian Computing wrote: Sun Mar 10, 2019 9:03 am The offset where the logo begins in TOS3.06 is 35FF4
For reference in TOS2.06 UK image the offset for the logo is 3257E and ends at 32985
thorsten.otto
Re: TT Boot Logo
Post by thorsten.otto »
The offset is not quite right, and also depends on the language of the TOS. For TOS 3.06(us), the logo starts already at $35fe8.
The table below should give the absolute address for all (official) tos versions (subtract $e00000 to get the file offset):
306us: e35fe8
306de: e36018
306fr: e36036
306uk: e35fe8
306es: e36044
306it: e36026
306sv: e36036
306sf: e36044
306sg: e36044
206us: e3257e
206de: e325ae
206fr: e325cc
206uk: e3257e
206es: e325da
206it: e325bc
206sv: e325ae
206sf: e325da
206sg: e325da
Most patched TOS versions that are floating around (like CZ and PL) are based on the german version.
The routine that displays the logo is located at $e0074a in TOS 3.06, and $e00762 in TOS 2.06 (for all language versions).
As already mentioned above, the logo is 96x86 pixels, thus 1032 bytes of data.
Atarian Computing
Re: TT Boot Logo
Post by Atarian Computing »
thorsten.otto wrote: Tue Dec 31, 2019 4:16 am The offset is not quite right, and also depends on the language of the TOS. For TOS 3.06(us), the logo starts already at $35fe8.
306us: e35fe8
306de: e36018
306fr: e36036
306uk: e35fe8
306es: e36044
306it: e36026
306sv: e36036
306sf: e36044
306sg: e36044
206us: e3257e
206de: e325ae
206fr: e325cc
206uk: e3257e
206es: e325da
206it: e325bc
206sv: e325ae
206sf: e325da
206sg: e325da
Now that you mentioned patched TOS versions, it occurred to me that since this is the ThunderStorm patched 3.06 TOS version (for obvious reasons), the offset might not be the same. Also, mine was the US version which I then changed to UK keyboard layout. So yeah, probably best to disregard my offset figures.
Re: TT Boot Logo
Thanks @thorsten.otto this is helpful information
thorsten.otto
Re: TT Boot Logo
Atarian Computing wrote: Tue Dec 31, 2019 8:36 am since this is the ThunderStorm patched 3.06 TOS version (for obvious reasons), the offset might not be the same.
The thunderstorm is only a patched TOS, i doubt that they changed all the addresses (although it would theoretically be possible if they used my source to recompile it). But you should be able to check it by disassembling it, the routine looks like
[00e0074a] 207c 00e3 5fe8            movea.l   #$00E35FE8,a0
[00e00750] 2278 044e                 movea.l   ($0000044E).w,a1
[00e00754] 1038 044c                 move.b    ($0000044C).w,d0
[00e00758] b03c 0002                 cmp.b     #$02,d0
[00e0075c] 6728                      beq.s     $00E00786
[00e0075e] b03c 0006                 cmp.b     #$06,d0
[00e00762] 6722                      beq.s     $00E00786
[00e00764] d2fc 0500                 adda.w    #$0500,a1
[00e00768] 303c 0055                 move.w    #$0055,d0
[00e0076c] 7205                      moveq.l   #5,d1
[00e0076e] 3418                      move.w    (a0)+,d2
[00e00770] 32c2                      move.w    d2,(a1)+
[00e00772] 32c2                      move.w    d2,(a1)+
[00e00774] 32c2                      move.w    d2,(a1)+
[00e00776] 32c2                      move.w    d2,(a1)+
[00e00778] 51c9 fff4                 dbf       d1,$00E0076E
[00e0077c] d2fc 0110                 adda.w    #$0110,a1
[00e00780] 51c8 ffea                 dbf       d0,$00E0076C
[00e00784] 6018                      bra.s     $00E0079E
[00e00786] d2fc 0280                 adda.w    #$0280,a1
[00e0078a] 303c 0055                 move.w    #$0055,d0
[00e0078e] 720b                      moveq.l   #11,d1
[00e00790] 12d8                      move.b    (a0)+,(a1)+
[00e00792] 51c9 fffc                 dbf       d1,$00E00790
[00e00796] d2fc 0094                 adda.w    #$0094,a1
[00e0079a] 51c8 fff2                 dbf       d0,$00E0078E
[00e0079e] 7e27                      moveq.l   #39,d7
In the first instruction you will see the address of the data. You may also notice that the routine only handles resolutions 6 (TT-High) and 2 (ST-High), and assumes ST-Low otherwise, so any patched tos versions with support for eg. NOVA cards may have that routine replaced by something else.
BTW there is an (quite old) program named TOSPATCH that is able to do such patches , if you know how to use it. The original archives can't handle all language versions, but german and us/uk should work.
alienkidmj12
Re: TT Boot Logo
Could a tool be written to do it ?
frank.lukas
Re: TT Boot Logo
Post by frank.lukas »
TOS_ICON ... (don't know if it works on other TOS versions besides the German one)
TOS_ICON.zip
(305.87 KiB) Downloaded 126 times
