Sure, but I don't know if I can get round to it before this weekend.terriblefire wrote: 13 Mar 2019 12:02 A quick email exchange with Toni Willen..
The ROM only checks for CAFE not the COCA...
@alenppc can you check address $B80000 on the ReV0 please with DiagROM?
TF330 Akiko Rev 0 Issue (SOLVED)
alenppc
- Moderator Team
Re: TF330 possible issue?
- Admin sponsor
No worries. I suspect we will see C0C0CAFE for a rev0.alenppc wrote: 13 Mar 2019 12:53
I’ll maybe slap together a tool to check.
go0se
Currently checking all CD32s that I currently have access to [4] for the revision 0 chip. I have a CD32 diagrom sitting here should I stumble across one.
Will update later on.
- Admin sponsor
Here is a program i knocked up to check Akiko revision.
https://github.com/terriblefire/terribl ... takiko.zip
Its in ADF and Exec form. Simply run the testakiko binary in AmigaOS (no WB needs loaded)
go0se
All four are revision A here unfortunately/fortunately.
supaduper
I just bast...ized Akira`s systest iso and put testakiko on it, tested and it works.
Just unzip the attatched file burn the iso, then cd at the prompt it will show CDTV_test dir, then just type testakiko hit Return and it will show what version you have
alenppc
- Moderator Team
Unfortunately the result is the same on the Rev 0, still reads it as 0xC0CA
supaduper
Hopefully Steve will find what register the Rev 0 is stored in when he gets that Mobo and can then ammend his test software
- Admin sponsor
Very odd that CBM didnt have a different verison for the chip. They were usually good at this sort of thing.
alenppc
- Moderator Team
Consoldering the CD32 was hastily built as a company saviour they probably didn’t do the usual diligence. Maybe it’s not possible to detect different revisions via software.
Users browsing this forum: CCBot and 3 guests
