The board takes a few seconds to boot, so black > grey is normal also, then the standard 3.1 IDE check delay comes.anton.gale wrote: Wed Mar 06, 2019 4:14 pm I have a PAL unit.
I will burn a DiagROM 1.1 tonight.
I will test the memory from $40000000 to $44000000.
The IRQ tests passed, I don't think the CIA test will pass from memory (I didn't think the CD32 had CIAs - or maybe you implemented them).
When trying to boot up with a normal ROM the screen sometimes goes from black -> grey, but I can't get to the boot menu with both mouse buttons pressed down.
With the jumper set to the DISABLESPEED the unit will start, but there are no boards detected in the boot menu (I assume this is normal).
The jumpers don't work like that anymore since the latest firmware, you have to close the bottom two sections of Disable and Speed in order to enable the card.
