to make sure your IP is added into the firewall whitelist, thanks
TF330 Akiko Rev 0 Issue (SOLVED)
- Admin sponsor
Re: TF330 possible issue?
Actually. Did you try a memory test in the range $40000000 to $44000000? The autoconfig just exercises the autoconfig path. Try the ram tests.
Anton, your card seems to be recognized & working fine in diagrom - as Stephen said the looping thing is a diagrom bug, so it really should be booting with a regular rom also. Do you get it listed in the Early Startup Menu?
- 8 Bit Dreams
- Moderator Team
These will report failiure Stephen, - cause he has NTSC unit!terriblefire wrote: Wed Mar 06, 2019 7:49 am
EDIT: try running the IRQ and CIA tests. And graphics tests.
- Admin sponsor
But they’ll give me a number and a clue about what is going on. I didn’t realise there were NTSC CD32s made... :/
Yes, they were sold in Canada, I have one of them.terriblefire wrote: Wed Mar 06, 2019 2:49 pm But they’ll give me a number and a clue about what is going on. I didn’t realise there were NTSC CD32s made... :/
- Admin sponsor
Nice. I should get hold of one for testing.
There is hardly any difference with the PAL version. The MB crystal is slightly different, the RF modulator is NTSC version and the through hole caps are not mounted backwards. That's it.
- Admin sponsor
Since the 14mhz signal is sampled at 100Mhz I can’t see that a few 100 kHz would make any difference to functional behaviour.
- anton.gale
I have a PAL unit.
I will burn a DiagROM 1.1 tonight.
I will test the memory from $40000000 to $44000000.
The IRQ tests passed, I don't think the CIA test will pass from memory (I didn't think the CD32 had CIAs - or maybe you implemented them).
When trying to boot up with a normal ROM the screen sometimes goes from black -> grey, but I can't get to the boot menu with both mouse buttons pressed down.
With the jumper set to the DISABLESPEED the unit will start, but there are no boards detected in the boot menu (I assume this is normal).
- Admin sponsor
The CD32 has CIAs (integrated in Akikio) and the tests passing is a critical indication that the clock syncing is working.
It doesn’t have the GPIO pins but the rest is there.
If you get the latest DiagROM run the A1200 IDE drove tests. It sounds IDE related to me.
