Check if your IP is banned
viewtopic.php?t=7286
ST-IDE-ROM Dev Board v1 - BETA Testers
PaulJ
Re: ST-IDE-ROM Dev Board v1 - BETA Testers
Post by PaulJ »
Just feed Harry.. looked a little lean. :girldance:
PaulJ wrote: Fri Mar 13, 2020 4:55 pm Just feed Harry.. looked a little lean. :girldance:
I just helped to fatten him up a bit as well :lol:
He should be quite happy now, I've also fed him :)
PaulJ
Post by PaulJ »
I knew down deep Harry is a glutton.. :sigh:
Oooh I forgot this: :girldance: :girldance: :girldance:
PaulJ
Post by PaulJ »
@exxos , what is the IDE connector pin pitch on the new 1.1 IDE board? Thanks
DoG
Post by DoG »
PaulJ wrote: Mon Mar 16, 2020 6:25 pm @exxos , what is the IDE connector pin pitch on the new 1.1 IDE board? Thanks
Check the part list/BOM in this thread. But I can help you right away, it is 2mm :D ;)
PaulJ
Post by PaulJ »
DoG wrote: Mon Mar 16, 2020 8:31 pm
Oh, its the 0.0787 pitch instead of the 0.1 pitch used on the initial board. :) :)
It's 44 pin ide isn't it, rather than standard 40 pin.
PaulJ
Post by PaulJ »
rubber_jonnie wrote: Mon Mar 16, 2020 9:04 pm It's 44 pin ide isn't it, rather than standard 40 pin.
Yup, the initial board used a header with 0.1" pitch. So the 0.0787402" pitch are the smaller connectors used with the 44 pin. Guess I'll have to order some one these header pins.
