ST-IDE-ROM Dev Board v1 - BETA Testers
Re: ST-IDE-ROM Dev Board v1 - BETA Testers
exxos wrote: Wed Feb 26, 2020 11:52 pm I use a SD to CF in my falcon without issues. its like one of these https://www.aliexpress.com/item/3235226 ... 4c4dOZswUB there are some bugged controller chips on some of those adapter boards though...
@exxos Much the same as I have, and both work in my A1200, but not with my cable, I think if I put a scope or meter on the power pins there will be something different with power where it works and where it doesn't.
rubber_jonnie wrote: Wed Feb 26, 2020 11:57 pm @exxos Much the same as I have, and both work in my A1200, but not with my cable, I think if I put a scope or meter on the power pins there will be something different with power where it works and where it doesn't.
https://www.exxosforum.co.uk/forum/viewt ... 151#p30151
looks like @PaulJ had one working...
exxos wrote: Thu Feb 27, 2020 12:01 am
His is 40 pin to 40 pin by the looks of things, with separate power. I have a similar CF adapter that works just fine, but it's the 44 pin deelys I want to fix, they're much more compact and neat.
They are cheap devices, just seems weird they work in one scenario and not the other.
PaulJ
Post by PaulJ »
Several of us purchased hddriver when we were testing @exxos 's IDE board. So there's a paid update hddriver 11.0 that I just picked up. We'll see if I can notice any changes.
[url][https://www.hddriver.net/en/prices.htmlurl] :coffee:
TimNaber
Post by TimNaber »
ST: TT030 10/32m; Falcon 030 14m(2); MSTe 4m; MST 4m(3); MST 4m AdSpeed; 1040STf 4m(4); ST 4m(2); MF 44 w/SCSI2SD(3); MF 30(3); MF30 w/Drem
8-Bit: 320XE w/Ultraspeed+/FIXXL; 320XE; 130XE w/Ultimate 1m; 600XL w/Ultimate 1m; 800XL w/Omnimon XL/Boss XL/Omniview XL; 800 w/Incognito; 800 48K; Black Box Enhanced(3); 1050 Super Archiver II; 1050 Happy(2); XF551 360K(2); XF551 720K; HD Tower 480m
PaulJ
Post by PaulJ »
PaulJ wrote: Fri Feb 28, 2020 2:43 pm Several of us purchased hddriver when we were testing @exxos 's IDE board. So there's a paid update hddriver 11.0 that I just picked up. We'll see if I can notice any changes.
[https://www.hddriver.net/en/prices.html] :coffee:
@PaulJ You Should be able to edit your posts up to 24 hours...
@PaulJ €10 I see, have you noticed anyything interesting with V11?
czietz
Post by czietz »
rubber_jonnie wrote: Fri Feb 28, 2020 4:58 pm @PaulJ €10 I see, have you noticed anyything interesting with V11?
On STs with Blitter (MegaST or upgraded STF) IDE is about 20% faster with HDDRIVER 11.
czietz wrote: Fri Feb 28, 2020 5:01 pm
@czietz Sounds like that's worth €10 to me!
