Runs at 1410 kb/sec just as the other r boards does.
DoG wrote: Sat Jul 13, 2019 8:37 am I changed my resistor packs on the address & data lines. Didn't do much. However, I moved the pins slightly inwards, on the plcc sockets, with a tool and cleaned them with IPA and now it seems to be stable. Tried the board in an other motherboard where I havn't made any chnges and it work fine in there as well. So bus resistor arrays wasn't needed to be changed. But can't hurt anyway so I'm happy.
So socket problem strikes again. Fun, fun, fun!
EDIT: Oh, I also swapped out the HC 68000 for a "normal" one. Just to make that clear.
Just building my second one of these, but I had a question.PaulJ wrote: Fri Jul 12, 2019 5:51 pm Well awhile back I purchased a second IDE test board from Harry. Final got around to building it. Got rid of the unneeded extra sockets and nibbled out a notch so mega top would fit on. Runs great and works with all the previously tested devices..![]()
Haven't tried that but its the the only way to know for sure since we don't have a schematic. You shouldn't hurt anything attempting that configuration but it should let you know if it's possible. I would remove the 68k and put in a socket. Having the socket on top is so ugly it makes me cringe so even if it worked I would change it buts that's personal preference.rubber_jonnie wrote: Tue Nov 26, 2019 6:19 pm
The IDE board works fine in another STFM where it is plugged into a socket and the CPU is plugged into the IDE board.
Thoughts on a postcard please....
