What versions of Tos were you guys putting on the eprom?
I've got everything else but the ATF.
ST-IDE-ROM Dev Board v1 - BETA Testers
Re: ST-IDE-ROM Dev Board v1 - BETA Testers
In lieu of buying a ROM I may borrow the one in my STF remake....
TOS versions we are using are TOS104 and TOS206Forgottenmyname wrote: 07 Mar 2019 10:44 What versions of Tos were you guys putting on the eprom?
Any of my ROM's will work, we are using 104/206.
The ATF1508 I will be getting some from mouser to include with the PCB. The code needs to "grow" a bit yet, so I haven't tried fitting it in a 1504... currently the code fits.. but it may not after i've dumped in more changes.. Will try and do the changes soon (laid up with flu again so on a go slow :( )
PaulJ
I kinda like 1.04 or 2.06 and the DiagROM. When you have a issue just remove the jumper.. anyway on the fast rom board. :D
I will buy an ATF programmer too but it's a little lower down the list at the mo.
So I have a question.
What sort of devices are people thinking of connecting to the IDE interface?
Are we looking at connecting old brick drives 3.5", laptop 2.5" or just using CF or the SD adaptors?
OK - make that two questions :)
One of the reasons for asking is that the standard 40 pin IDE headers are quite large but if most people are looking at CF, SD or 2.5" drives then the smaller 44pin headers would take up less space on the next board.
I have a mix of IDE full size and laptop, plus IDE to CF. Personally I'd say that I'd prefer the final device to use laptop style connectors rather than full size IDE since the laptop drives and IDE-CF/SD adapters tend to use that format, plus it also carries the power, so you don't need an additional power lead.Icky wrote: 08 Mar 2019 08:51 So I have a question.
And of course, its much easier to fit those devices into an ST!
DoG
I vote for IDE44 also.
Yeah it's likely to be something like CF that I dnd up using. I got all of these 3.5 hds just so we had some more test subjects.
