Nah, that should be more like Wreck it Ralph.
Just doing the partitioning now, then will send a photo etc
Just a reminder that the HDD Test program is here https://www.exxosforum.co.uk/forum/viewt ... 642#p18545 if you want to do some write / read testing.
PhilC wrote: Wed Apr 10, 2019 7:20 pm Will download the test program in a mo but here's the requested photos
Device type is a Toshiba THNCF2G04QG 2.0GB, formatted to 4 partitions.
Nice list of stuff. I think we did talk about a list of cards that work and that don't. Exxos and I did have one knocking about from our tests. Will try and dig it out and put on here. Could you list your CF cards make etc that work and the one that doesn't so we can add to the list.PhilC wrote: Wed Apr 10, 2019 9:36 pm Thanks Paul, unfortunately that's a bit too expensive for my needs but does look like a good programmer.
But anyway, a productive evening:
1, learned how to set up Atari HDs.
2, Fixed my non working LED.
3, Tested a 2GB and 4GB CF card with the IDE and all worked ok, even with the HD test program.
4, Found that one of my other 4GB CFs, the Mega doesn't even boot, just a grey screen But this CF card works fine under windows.
5, Gembench test shows everything is normal under 8mhz.
6, Mega wont boot at all with the 1.5 booster at 16mhz.
7, I get very bored waiting for the HD test program to finish.
@Icky & Exxos, would either of you like the non functional CF to test?
The iffy card I had, I did not list it, because it was working on the PC either. So I just put it down to a faulty card.Icky wrote: Wed Apr 10, 2019 9:57 pm Nice list of stuff. I think we did talk about a list of cards that work and that don't. Exxos and I did have one knocking about from our tests. Will try and dig it out and put on here. Could you list your CF cards make etc that work and the one that doesn't so we can add to the list.
