TF330 Rev 3 arrives
68030 + SDRAM + IDE
supaduper
Re: TF330 Rev 3 arrives
Post by supaduper »
C11 is 100nf, basically all the top board 0603 caps are 100nf as well as the two on the underside next to the 10uf caps, but the two 0603 inside
the PGA socket are 1uf so make sure you get those right, there is an updated BOM I did for the Rev 2 which is the same as the REv 3 its in one of the TF330 threads somewhere
go0se
Post by go0se »
Cheers guys, and apologies SupaDuper, I was looking at the old version, the Rev2 (i.e. Rev3) version that you posted can be found here for anyone else that is looking:
https://www.exxosforum.co.uk/forum/viewt ... =10#p16993
Thanks.
go0se
Post by go0se »
Here's a TF330 build with a cooling 'solution' for those of you that might be interested:
The heatsink is a 28mm X 28mm x 8mm easily found on eBay. It is secured using Arctic Alumina Silver thermal adhesive (two part epoxy) and so does not require any additional mounts on the board. The 8mm height still allows the 330 to slot easily into the CD32 case at an initial angle. You could probably get away with up to 12mm height and sides much wider than 28mm however these seem to give good performance for very little £.
It states on the Arctic website that this adhesive is not intended for use on CPUs however I'm taking that to refer to modern CPUs that require large heatsinks and active cooling in conjunction with a high quality thermal paste rather than an 030 that can run happily without a heatsink at all. I have been running a couple of these for the past few days and they seem very happy.
The processor pictured is a MC68030RP33B.
go0se
Post by go0se »
Booooo! :(
Has anyone successfully used an alternative to these chips on the TF330? I assume this will also affect the TF536 in its current incarnation?
Edit: I see that Mouser still have plenty in stock for now but they're also marked as "End of Life"
alenppc
Post by alenppc »
The official RAM chip for the 330/536 is MT48LC16M16A2P-6A:GCT-ND, it's stocked and still active.
https://www.digikey.ca/product-detail/e ... ND/5069732
EDIT: for the chip you quoted, there is none on mouser either, but they have plenty of the official ones.
I picked a chip that was active on RS.
go0se
Post by go0se »
Ah, yes apologies, the helpful Mouser search came back with a similar chip as the one I searched for wasn't in stock.
Looks like I'll be using the recommended official parts from now on then. Cheers.
alenppc wrote: Tue May 28, 2019 3:58 pm The official RAM chip for the 330/536 is MT48LC16M16A2P-6A:GCT-ND, it's stocked and still active.
supaduper
Post by supaduper »
Here is one of the Green PCB TF330 Rev3b that Steve has released , and is available to purchase with special offer to EXXOS members
Available with CPU 030/40mhz EC, or full 030/50mhz with MMU
TF330 Green PCB Ebay.jpg (197.13 KiB) Viewed 7024 times
bytestorm
Post by bytestorm »
Nice! :) Whats new in the TF330 rev 3 B version?
Longtime arcade collector/repairer. Finally back into Amigaverse!
I think it was 2 pull ups.
Return to “TF330”
