PhilCs blog / the latest things hes broken(fixed)
Re: PhilCs blog / the latest things hes broken(fixed)
@mrbombermillzy I don't mind them needing work as such, that's part of the fun. The PS1 cost me a tenner but doesn't read disks.
If you spot an original PS3 then give me a shout. I owned one back in the day but the ex wife took it.
I reckon you'll find a good PS3 and all it'll need are Tokin replacements, I've had a couple of cheap ones from ebay, pretty good consoles.
rubber_jonnie wrote: Tue Apr 08, 2025 9:45 pm I reckon you'll find a good PS3 and all it'll need are Tokin replacements, I've had a couple of cheap ones from ebay, pretty good consoles.
Weren't they those odd shaped caps?
mrbombermillzy
Post by mrbombermillzy »
You know what Phil, I have one of the fat original PS3 consoles that seems to be just starting to overheat and lock up.
Ive taken it out of action now, as I didnt want to fry it and was going to blast out the dust and re-paste.
Im happy to put that on our 'deal list', if you are good to wait for CL, or I can perhaps post it if you want it ASAP?
Its a bit late to be banging around the house tonight, but I will get you the exact model number tomorrow (its the one with the built in backward compatibility chip, rather than SW emulation the later ones had).
PhilC wrote: Tue Apr 08, 2025 10:04 pm
Yeah, big rectangular multi-layered fellas.
I replaced some on my PS3 that had a YLOD. They fall apart when you heat them, but you can just install tantalums and it'll work just fine, I got a kit to do mine. Probably impossible to install Tokins yourself, but fitting alternatives is easy. I fitted individual tantalums but you can get a thing called The Tanatalizer" which is a PCB that drops in directly in place of a Tokin.
Have a look here: Tokins
Just a very quick update for today. The new PS2 to HDMI adapter arrived and the good news is the PS2;works great so far.
Yesterday I ended up giving it a clean inside as well, so we will see how it goes. so far the fan is a little noisy but that's normal for a PS2, so I'll see about sourcing a quieter replacement.
Just got to wait for the PS1 to arrive next.
Bit of Need for Speed anyone?
Hellraiseruk
Post by Hellraiseruk »
Need for Speed? Pah, Burnout all the way....
JD
Hellraiseruk wrote: Wed Apr 09, 2025 6:57 pm Need for Speed? Pah, Burnout all the way....
JD
Yeah I used to play that back in the day. This is the only disk I've got at the moment though :lol:
Hellraiseruk
Burnout is one of my favourite games, a pure reflex tester - excellent fun :)
JD
All I need is a PS5, I have the others 😁
Also have OG Xbox, 360, One and Series X 😁
I am a lucky boy.
