PhilCs blog / the latest things hes broken(fixed)
Re: PhilCs blog / the latest things hes broken(fixed)
Post by JezC »
Turn it on its side & you've re-created The Matrix
:lol: :roll: :hide:
HigashiJun
Post by HigashiJun »
:lol:
Well that's just annoying, the Reuters monitor is just about working, very nearly. I managed to tweak all the adjusters but the horizontal amp variable inductor as it's now jammed and broken.
So I've got to try and track one of those down with no idea what to get as the existing one has no markings on it whatsoever.
Does anyone have any experience with sourcing replacements? I'll post a pic a little later on.
I've a couple in an old telly I could do with replacing... and again, no markings. *sigh*
stephen_usher wrote: Mon Jan 27, 2025 4:24 pm I've a couple in an old telly I could do with replacing... and again, no markings. *sigh*
I think with the heat old electronics makes the grease on the adjusters turned into glue.
PhilC wrote: Mon Jan 27, 2025 5:47 pm
And the plastics just get extremely brittle too, so the threads disintegrate.
mrbombermillzy
Post by mrbombermillzy »
Was just wondering Phil, the Reuters monitor is very likely a rebadged unit.
Perhaps finding the actual manufacturer may open the options for finding a service manual with the pertinent information?
I think my one even had the same model no. between the Reuters and the OEM manufacturer.
@mrbombermillzy it does have the proper manufacturer details on the back, K.G.M. Electronics LTD but all I could find was the companies house details and the details of the company closing.
I think ax soon as I can solve the horizontal size issue with another variable inductor I'll be sorted.
I've managed to get the old ferrite screw out and hopefully found a couple of new ones on eBay, so hoping I can get it working and glue the whole thing back together once it is.
So while I wait for the ferrite screws to arrive I thought I'd get one of my old keyboards out to play. I've had it since it was nearly new. Only to find out the battery backed up memory wanted changing, not bad though for thirty years :lol:
That's changed, fixed a couple of sticky keys and gave it a quick look over and loaded up the default patches.
Look and plays much better now.
mrbombermillzy
Ah! The Kawai K4!
I almost bought one of those as my first synth. (Well the K4R).
I ended up with a TG-55, which was Yamahas close effort.
You'll have to bring it to the next CL.
We can definitely do a HIFI/Synth corner! :)
