PhilCs blog / the latest things hes broken(fixed)
Re: PhilCs blog / the latest things hes broken(fixed)
And of course I’ve spoke too soon, the HT has now started to make that distinct high pitched whine that it does. Fortunately I have a spare analogue board, so let’s hope the pinout is the same.
PhilC wrote: 04 Mar 2024 16:29 And of course I’ve spoke too soon, the HT has now started to make that distinct high pitched whine that it does. Fortunately I have a spare analogue board, so let’s hope the pinout is the same.
Speaking to soon is something we all need to get out of the habit of!
@rubber_jonnie especially when your spare analogue board is slightly different annoyingly. It’s got a different Ht coil. Might have another somewhere, fingers crossed.
PhilC wrote: 04 Mar 2024 16:42 @rubber_jonnie especially when your spare analogue board is slightly different annoyingly. It’s got a different Ht coil. Might have another somewhere, fingers crossed.
Is it from the same machine or something different?
rubber_jonnie wrote: 04 Mar 2024 16:49
Same machine but the analog board must be a different revision.
PhilC wrote: 04 Mar 2024 16:53
Surely it should work then?
@rubber_jonnie hopefully it will but the other board I have has a slightly different connection for the wires going to the CRT, nothing I can’t fix though.
PhilC wrote: 04 Mar 2024 17:34 @rubber_jonnie hopefully it will but the other board I have has a slightly different connection for the wires going to the CRT, nothing I can’t fix though.
In what way are they different? For the neck board or the coils around the neck?
@rubber_jonnie its the deflection coils plug that’s the main difference, the spare board has an offset pin but this one doesn’t. Then of course I haven’t got and radial 2200uf or 470uf caps to complete the recap.
I’m going to see if I can find a new HT coil for it. Something a bit like this.
PhilC wrote: 04 Mar 2024 20:13 @rubber_jonnie its the deflection coils plug that’s the main difference, the spare board has an offset pin but this one doesn’t. Then of course I haven’t got and radial 2200uf or 470uf caps to complete the recap.
Danger Danger, High Voltage :)
Check out the song on YouTube :)
Users browsing this forum: CCBot, EvilFranky, stephen_usher and 14 guests
