PhilCs blog / the latest things hes broken(fixed)
Re: PhilCs blog / the latest things hes broken(fixed)
:bravo: :fire: :fire: :fire: :fire: :fire: :fire:
@PhilC - Nice!
Should take about 5-6 days but don't forget the import duty :(
Patched TOS 1.04 with the IDE patch, and it works fantastically.
Will post a boot up video and links later.
Well done, IDE with good compatibilityrubber_jonnie wrote: 03 Apr 2020 18:15 Patched TOS 1.04 with the IDE patch, and it works fantastically.
These arrived in the post today.
The larger one is the Megabus to 68k socket adaptor. The idea behind this is that a Mega ST can use two 68k upgrades without stacking
The smaller one is a Megabus to IDE adaptor but with inline buffers. Its based on the PP interface. I've added an ATF22V10 instead of the Gal as the chips are still easily obtained.
:thumbup: You could move that LS chip into the GAL now you got a 22V10. PP only used it for its open collector, as the 16V8 couldn't do that. The 22V10 can.
Sounds like a plan for version 2 then :Dexxos wrote: 14 Apr 2020 11:06 :thumbup: You could move that LS chip into the GAL now you got a 22V10. PP only used it for its open collector, as the 16V8 couldn't do that. The 22V10 can.
Nice!
I see JLC are sending out insulation tape with all their PCB orders now. :)
I didn't have any green but now I do :)Icky wrote: 14 Apr 2020 11:25 Nice!
Ahh, cool, be interested in your IDE results :)
Users browsing this forum: CCBot and 80 guests
