Here is a picture of the TOS 2.06 upgrade board from WongCK’s website:
Project STacy (STaceX, TOS 2.06 & others)
Atarian Computing
Re: Project STacy (STaceX, TOS 2.06 & others)
Bama
I wish I had seen this earlier...several members of the Atari-Forum helped me with the same question.Atarian Computing wrote: 03 Oct 2017 13:17
Thank ya! So it turns out that STacy has a regular TOS. Nothing special about it.
http://www.atari-forum.com/viewtopic.ph ... 99#p313374
Bama
Atarian Computing
I did read your thread carefully. I wasn’t quite sure how it worked since you had an external monitor connected to it.Bama wrote: 05 Oct 2017 03:04 I wish I had seen this earlier...several members of the Atari-Forum helped me with the same question.
Bama
I have now installed a new screen. Exactly the same as here: http://www.falconproductions.us/blog/ne ... splay.html
Nice and bright! Huge difference!
I wonder if it is worth asking permission from that guy to include is information here ? There is not much Stacey information anywhere I think, so if we had a copy hosted on here would help keep things more in one place..Atarian Computing wrote: 05 Oct 2017 16:22
Bama
Wow, what a difference!Atarian Computing wrote: 05 Oct 2017 16:22I did read your thread carefully. I wasn’t quite sure how it worked since you had an external monitor connected to it.Bama wrote: 05 Oct 2017 03:04 I wish I had seen this earlier...several members of the Atari-Forum helped me with the same question.
Bama
Anyone know how this compare to the improvement in brightness after replacing the EL panel?
Darklord
Re: Project STacy (STaceX & others)
She sure is! I've always admired the STacy's sleek lines and look.
Atarian Computing
I wrote to him asking for it.exxos wrote: 05 Oct 2017 16:48 I wonder if it is worth asking permission from that guy to include is information here ? There is not much Stacey information anywhere I think, so if we had a copy hosted on here would help keep things more in one place..
Awesome. I have moved it to its own thread so it's easier to find for people in the future :).
https://www.exxosforum.co.uk/forum/viewt ... f=17&t=297
Atarian Computing
PCB on its way and components ordered. Uses 2Mbit ROMs for TOS switching. TOS 2.06 decoding on bottom side. Hopefully it will work :)
Users browsing this forum: Baidu [Spider], CCBot and 9 guests
