TF330 Soft Reboot Issue (SOLVED)
68030 + SDRAM + IDE
Re: TF330 LoadResident Issue
It’s definitely a rabbit hole....
Is the source available?
What I’ll do is setup a synchronous 14mhz firmware to test these things with. If that doesn’t work with no ram then I’m not chasing it any further.
alenppc
Post by alenppc »
supaduper wrote: Tue Jan 29, 2019 2:40 pm Are we going down a Rabbit hole with this LoadResident thing as there were always problems in the past with some software and some 030/40/60 accelerators
This is not a CPU issue, it is basically part of the modern AmigaOS so it works on any CPU.
One thing I should mention is that in my tests I disabled FastRAM via software (by using NoFastMem basically before issuing a Loadresident), not by flashing a no-ram firmware. Not sure if that makes a difference.
Also supaduper can you confirm the "Boot with no Startup-Sequence" freeze on the rev2?
It’s entirely possible that the CD32 rom has something that doesn’t like the 030 in it. That’s why I asked if someone could burn a 27C800 with vanilla AmigaOS and try this. Even if it’s just an interaction with Akiko I’d like to rule out the OS.
My issue right now is I have 20 mins a day at my bench and all my CF cards are dodgy.. none of them are loading properly on any of my cards.. I suspect dodgy cables etc because that’s the only common element
alenppc
Post by alenppc »
I wonder if it'll boot with a regular 27C400. I can try with an A500 rom.
Stephen you should try with the kipper's CF adapter, that one has no cable.
Yeah that one has vanished. Can’t find it. I have too much crap to store. This is why I resist people wanting to send me stuff
The 27c400 will not work... the CD32 does a mad stunt for 32 but wise accesses
supaduper
Post by supaduper »
alenppc wrote: Tue Jan 29, 2019 3:29 pm
Can confirm Freezes with "Boot with no Startup-Sequence"
alenppc
Post by alenppc »
supaduper wrote: Tue Jan 29, 2019 4:02 pm
Should we open a new thread/bug for this one? :)
alenppc
Post by alenppc »
terriblefire wrote: Tue Jan 29, 2019 3:58 pm Yeah that one has vanished. Can’t find it. I have too much crap to store. This is why I resist people wanting to send me stuff
I always assumed the CD32 rom was 16 bit access only, especially considering it has a place for a second rom on the motherboard. So the designers pulled off a 32 bit access with a single chip? That's some sorcery.
supaduper
Post by supaduper »
Just to add I tried the " Boot with no Startup-Seq" again a few times and this time it goes to Amiga Dos, so inputed LoadWB and it boots ..go figure
Return to “TF330”
