STe booster v 1.5 36Mhz
nemox
Re: STe booster v 1.5 36Mhz
Post by nemox »
Hi,
I am install dma chip from board without externall blitter to board with external blitter and all working fine :-)) wire for clock booster is koaxial 50ohm without termination. All test ok . Super...
Great well done!
nemox
Post by nemox »
Neverending story.
Problem - 32 Mhz with tos 2.06 and blitter,
and this blitter warm up to about 25 Celsius - when I move with the window - screen is damage.
when i cooled the bliter with cool finger screen is OK.
On 8 mhz is all OK.
And strangely is: in Tos 1.62 it doesn't happen, only in Tos 2.06
i will istall peltier article and everything will be ok :-) is joke
any idea?
another blitter chip ?
thanks
Possible could be blitter is not happy.
Though all these problems is basically why I just stopped making booster for STE, because they are just never ending trouble on some machines.
nemox
Post by nemox »
Hi
resistor p100 has 2.2kohm, can i try replace resistor for 1.2k, or cut power line to blitter and add to series diode to low voltage, what do you thing about this
thanks
nemox wrote: Wed May 15, 2019 8:28 pm resistor p100 has 2.2kohm, can i try replace resistor for 1.2k,
You could try it.
nemox wrote: Wed May 15, 2019 8:28 pm or cut power line to blitter and add to series diode to low voltage, what do you thing about this
Nothing I ever tried or needed to do. So I really can't comment.
nemox
Post by nemox »
Hi, gut news. I replace blitter and works. :D
DoG
Post by DoG »
Great work! I need to get started with mine to get it working. Just installed it when I bought it but never got a screen.
Another Atari, a STfm I was working on, also didn't show a screen. Turns out that I have some problem with a hdmi cable, OSSC, flatscreen or/and scartcable. Display sometimes. *sigh* So it seems that it wasn't the STe fault.
Is your running at 32MHz or 36MHz now?
nemox
Post by nemox »
I'am running on 32MHz, clock from motherboard.
