PAK issues
Re: PAK issues
new u4
Re: PAK issues
Forgottenmyname wrote: Fri Feb 08, 2019 10:20 pmnew u4
Ok, not sure if that Gal worked as just programmed yet another Gal v4_50ac and it boots again
pakman
Re: PAK issues
Post by pakman »
Strange. The only explanation I see is that something went wrong with the programming.
Which GAL and which programmer are you using?
Re: PAK issues
I am using lattice gal20v8b 15lph.
The programmer is a tl866 2 plus with latest software
pakman
Re: PAK issues
Post by pakman »
Both sounds good to me. Please read back the JEDEC from the GAL U4 and send it to me.
Re: PAK issues
Just pmd the file to you
czietz
Re: PAK issues
Post by czietz »
Forgottenmyname wrote: Fri Feb 08, 2019 10:33 pm I am using lattice gal20v8b 15lph.
Did you really select GAL20V8B in the software while programming? The different versions (with different letter prefixes) require a different order of programming the fuses. If you write a GAL20V8B for example as GAL20V8, it'll be programmed wrong. It will seemingly read back correctly, because the programmer of course reads back the fuses in the same (incorrect) order in which it programmed them. Still the GAL will not work.
Re: PAK issues
Good advice and yes it was the GAL20v8B set on the programmer.
pakman
Re: PAK issues
Post by pakman »
That's the wrong JED file!
The read back JED is "V4_50ac" (thats an older revision).
Please use "P4_52", which I have sent.
And please check the other GALs as well, make sure its the latest revision.
Re: PAK issues
I dont know ho i managed to get them mixed up
I am reprograming with the latest ones again, should i try boot with them all in? or just 3,4 and 5?
