PAK issues
pakman
Re: PAK issues
Post by pakman »
Next: Remove the U5 jumper wire, and assemble U5 instead. Try to boot.
Re: PAK issues
with U5 inserted and the wire removed from U1 also it does boot to desktop
pakman
Re: PAK issues
Post by pakman »
Ok, add GAL U4 and try to boot
Re: PAK issues
It gets to desktop with U4 inserted as well but wont boot the floppy image I had on Gotek but one step at a time :)
pakman
Re: PAK issues
Post by pakman »
That's weird. Check the voltage at U4 pin13, should be high. Then all outputs of U4 should be tri-stated, essentially the same as if there were no U4 at all.
Re: PAK issues
I have 4.48v on U4 pin 13
Re: PAK issues
I've also put u2 back in and it boots if that helps
Edit:
In fact it ill boot with all 5 Gals inserted
pakman
Re: PAK issues
Post by pakman »
Let's fix U4 first. Get another GAL (not the U4 you are using right now), program the P4 JEDEC, and try again to boot.
Re: PAK issues
Ok, just U3, U$ and U5 inserted and it now doesn't boot
pakman
Re: PAK issues
Post by pakman »
The very same U4 as before? Or a new U4?
