Its more of a gut thing with this one. i'd start with 50 ohms and see where you get to.kludge wrote: 10 Mar 2019 08:34What's a recommended value for RCLKLOAD?terriblefire wrote: 08 Mar 2019 07:26 There is a resistor pad in the Rev 3 for this purpose. North of the RaM cpld next to the SPI port.
kludge’s TF530 build
- Admin sponsor
Re: kludge’s TF530 build
kludge
I'll order an assortment of 0603's then. Any idea what values I could need? 50, 500, 5k? 50, 100, 150? I have no clue :)terriblefire wrote: 10 Mar 2019 08:53 Its more of a gut thing with this one. i'd start with 50 ohms and see where you get to.
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
My lack of focus:
- Admin sponsor
I never got this to work well. Hence why i redesigned the board as the TF534.kludge wrote: 10 Mar 2019 08:58I'll order an assortment of 0603's then. Any idea what values I could need? 50, 500, 5k? 50, 100, 150? I have no clue :)terriblefire wrote: 10 Mar 2019 08:53 Its more of a gut thing with this one. i'd start with 50 ohms and see where you get to.
PaulJ
Out of curiosity what did you do to enhance the design in the 534? :?: :?: :?:
kludge
I think that the main difference in this regard is 4 layers instead of two, making for a proper ground plane.PaulJ wrote: 10 Mar 2019 14:58 Out of curiosity what did you do to enhance the design in the 534? :?: :?: :?:
My lack of focus:
My lack of focus:
- Admin sponsor
No its massively more than this. I basically spent a month doing what your doing to the clock lines and got nowhere. I completely redesigned the topology of the clock. I no longer sell the TF530 because of this.
PaulJ
So terrible fire, would recomend bypassing the 530 and go directly to the 534? I didn't place the order for the 534's since I was going to build the 530's first. Sounds like maybe I should just bypass the 530's. The 534's gave me pause due to one of the cpld's has a smaller pin pitch than the cpld's used on the 530. Never the less what do you recomend?terriblefire wrote: 10 Mar 2019 15:17
- Admin sponsor
You get more RAM, better clocks and you can use existing ZII ram which you cant with the 530.. and 44pin IDE.. The pitch is a bit harder but not massively so.
PaulJ
Sounds good, I've put in for 2 of the last eight. Give me the word and I'll forward the payment. :D :D :D
kludge
Sorry, it wasn’t my intention to downplay the work you put into it. I’ll probably spend two months on and off and then throw it in the trash.terriblefire wrote: 10 Mar 2019 15:17 No its massively more than this. I basically spent a month doing what your doing to the clock lines and got nowhere. I completely redesigned the topology of the clock. I no longer sell the TF530 because of this.
My lack of focus:
My lack of focus:
Users browsing this forum: CCBot and 10 guests
