Damage done to my STE
Bikerbob
Re: Damage done to my STE
Post by Bikerbob »
Bikerbob wrote: Thu Sep 19, 2019 8:47 pm Sorry Chris, I dont understand just 2 pictures? So your saying there is only the one trace that goes to the Via to the other side.. thats it?
I highlighted the trace you was questioning... I think your not seeing exactly where the traces go and its resulting in the confusion.
Bikerbob
Post by Bikerbob »
So then as I said.. just the one trace that goes to the via to the other side of the board to the ROM?
James
Bikerbob wrote: Thu Sep 19, 2019 9:52 pm So then as I said.. just the one trace that goes to the via to the other side of the board to the ROM?
I don't know which vias your referring to.. I highlighted the ones you mention anyway.. its better just to look at the images to see where things go.
Bikerbob
Post by Bikerbob »
This is why sometimes this is better in PMs.. there seems to be a communication issue.. So layer 4 is the bottom? where I pulled the pad from?
SO I will need to jumper to make the trace you highlighted work.. correct?
James
I think this one is your only issue you had....
https://www.exxosforum.co.uk/forum/viewt ... =30#p26304
Bikerbob
Post by Bikerbob »
Fixed! - fired up and working.
Have an HXC Gotek with it.. need to figureout how to setup the USB drive... off to the website!
James
derkom
Post by derkom »
Bikerbob wrote: Thu Sep 19, 2019 6:21 pm Are you saying that if the TOS switcher is in.. and there is no floppy connected to the cable that there would be boot issues?? but not at the point I am at correct??
you would get a screen etc??
Because I dont have a floppy connected in testing this.
It's a TOS 2.06 misbehaviour issue that I knew eons ago, but had forgotten before installing the TOS switcher in the STe I picked up. Without a floppy connected, it'll do the RAM test, but then four bombs instead of move on to the desktop. Unrelated to the TOS switcher.
Bikerbob wrote: Fri Sep 20, 2019 6:36 am Fixed! - fired up and working.
James
Try here as well for Gotek :)
https://www.exxosforum.co.uk/forum/viewt ... ilit=gotek
Bikerbob
Post by Bikerbob »
rubber_jonnie wrote: Fri Sep 20, 2019 9:02 am
James
Thanks - yep I know FF.. this one has HXC on it.. so thought I would try it. Never played with it. I have played with FF for years though.. Keir has done some terrific stuff.
James
