CDTV Power Supply
CDTV Power Supply
So there is a fuse in the CDTV power supply which I appear to have killed
Symptoms are dead front panel and furiously spinning power supply fan.
Re: CDTV Power Supply
Must have 12V then for the fan to be working ? assuming the fuse is ok in that case ?
exxos wrote: Mon Jan 07, 2019 6:44 pm Must have 12V then for the fan to be working ? assuming the fuse is ok in that case ?
Fuse was dead. So dead it disintegrated as i removed it.
terriblefire wrote: Mon Jan 07, 2019 7:11 pm Fuse was dead. So dead it disintegrated as i removed it.
Have you tried a new fuse then ? see if you get, I assume, 5V output ?
8 Bit Dreams
Post by 8 Bit Dreams »
seems this fuse is for +5v rail only, 12v has its own. Almost all old fans are 12v..
Any signs of life after swapping it out?
Confirmed fan spins with fuse removed.
Actually don’t have a replacement. I’ve ordered up a pack.
Return to “TF534 (OBSOLETE)”
