Unless the design is fundamentally different to the A500. I don’t trust the PCB explorer. Look at the published schematics. Either way if you pull VPA low you will cause chaoskludge wrote: 22 Mar 2019 10:29Because I want to pull BR low for the bus arbitration, and by doing that VPA would also go low as they are tied together on the A600. I can’t see how these could be used to communicate with the CIAs as there doesn’t seem to be any traces between the chips. At all.terriblefire wrote: 22 Mar 2019 10:24 If you mess with these lines and/or don’t connect them to the Amiga then the machine won’t work.
Why would you pull them up if the Amiga already does this anyways??
This is weird.
A600 CPU adapter (PLCC to DIP64)
- Admin sponsor
Re: Compatibility issues with TF530/TF534 and A600?
kludge
I’ll check the schematics. My point is that what I’m doing now is pulling VPA low “by mistake” by pulling BR low. And I want to correct that. _IF_ PCB Explorer is correct.terriblefire wrote: 22 Mar 2019 10:36 Unless the design is fundamentally different to the A500. I don’t trust the PCB explorer. Look at the published schematics. Either way if you pull VPA low you will cause chaos
I’ll check and come back here with results. Good or bad :)
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
My lack of focus:
kludge
From http://www.ianstedman.co.uk/downloads/a ... matics.pdf. BR pulled up together with VPA. E and VMA unconnected. Does seem to differ from A500 then.
My lack of focus:
My lack of focus:
- Admin sponsor
Ok. Then pull BR low on the Amiga and cut the trace to the DiP VPA and pull it high with a botch wire.
kludge
Yup, that’s the plan. We’ll see what happens :)terriblefire wrote: 22 Mar 2019 11:38 Ok. Then pull BR low on the Amiga and cut the trace to the DiP VPA and pull it high with a botch wire.
My lack of focus:
My lack of focus:
- Admin sponsor
probably worth being able to undo that with a jumper as the STE will not be able to reuse that adapter without VPA.kludge wrote: 22 Mar 2019 11:52Yup, that’s the plan. We’ll see what happens :)terriblefire wrote: 22 Mar 2019 11:38 Ok. Then pull BR low on the Amiga and cut the trace to the DiP VPA and pull it high with a botch wire.
kludge
Wouldn’t the board need to be redesigned to fit in the STE anyway? But for testing, absolutely.terriblefire wrote: 22 Mar 2019 12:38 probably worth being able to undo that with a jumper as the STE will not be able to reuse that adapter without VPA.
My lack of focus:
My lack of focus:
kludge
Holy hell!
@U
Garbage before this text was binary numbers: 1, 2, 4, 8, 16, 32, 64, 128, 240, 15, 170 and 85
To help you find biterrors to paula. Now starting normal startuptext etc
Amiga DiagROM V1.1 - 01-Jan-19 - By John (Chucky/The Gang) Hertell
Testing if serial loopbackadapter is installed: <> NOT DETECTED
- Parallel Code $ff - Start of ROM, CPU Seems somewhat alive
Checking status of mousebuttons for different startups:
Set all Interrupt enablebits (INTENA $dff09a) to Disabled: Done
Set all Interrupt requestbits (INTREQ $dff09c) to Disabled: Done
Set all DMA enablebits (DMACON $dff096) to Disabled: Done
Testing if OVL is working: OK
- Parallel Code $fe - Test UDS/LDS line
- Test of writing word $FFFF to $400 OK
- Test of writing word $00FF to $400 OK
- Test of writing word $FF00 to $400 OK
- Test of writing word $0000 to $400 OK
- Test of writing byte (even) $ff to $400 OK
- Test of writing byte (odd) $ff to $401 OK
- Parallel Code $fd - Start of chipmemdetection
Addr $001F8400 OK Number of 32K blocks found: $40
Startaddr: $00000400 Endaddr: $00200000
Using $001ECD00 as start of workmem (Base)
- Parallel Code $fa - Starting to use detected memory
Detecting if we have a working raster: DETECTED
Detected Chipmem: 2048kB
Detected Motherboard Fastmem: 4294967232kB
Basememory address: $001ECD00
- Parallel Code $f9 - Detected memory in use, we now have a stack etc
Set Start of copper (COP1LCH $dff080): Done
Starting Copper (COPJMP1 $dff088): Done
Set all DMA enablebits (DMACON $dff096) to Enabled: Done
Set Beam Conter control register to 32 (PAL) (BEAMCON0 $dff1dc): Done
Set POTGO to all OUTPUT ($FF00) (POTGO $dff034): Done
- Parallel Code $f8 - Starting up screen, text echoed to serialport
Doing ROM Checksumtest: (64K blocks, Green OK, Red Failed)
$FE7E7A85 $F2DA8CE7 $46764915 $00000000 $00000000 $00000000 $00000000 $006C0070
CPU: 68010 FPU: NONE MMU: NOT CHECKED
Doing some fastmem detection skipped at start as chip was found
Pressing left mousebutton will cancel detection (if hanged)
Checking if a 24 Bit address cpu is used: YES
- Checking for Memory in 24 Bit area (NON AUTOCONFIG)
- Checking for Memory in Ranger or Fakefast area
IF This ROM is sold, if above 10eur+hardware cost 25% MUST be donated to
an LEGITIMATE charity of some kind, like curing cancer for example...
If you paid more than 10Eur + Hardware + Shipping, please ask what charity you
have supported!!! This software is fully open source and free to use.
Go to www.diagrom.com or http://github.com/ChuckyGang/DiagROM for information
To use serial communication please hold down ANY key now
OR click the RIGHT mousebutton.
Holding down the LEFT mousebutton will force serial on and turn off screen
forcing stuff to run in fastmem if avaible
No key pressed, disabling any serialcommunications. Enable it in programYou do not have the required permissions to view the files attached to this post.
My lack of focus:
My lack of focus:
Justme14
Hoa !,
Way to go man ! :dualthumbup:
Now testing a TF board would be very intrestring :P
kludge
Two problems with that plan:Justme14 wrote: 22 Mar 2019 14:54 Hoa !,
One: I still haven't got a working TF53x card. It's in the works.
Two: The adapter is two millimeters too tall, so the TF53x wedges against the back wall of the A600. I'll see if I can find a workaround.
My lack of focus:
My lack of focus:
