I can't remember if I posted images of this before or not..
Ultrasatan will *just* fit under the floppy drive. The is parts sticking up on US which are in the way of the chips on the MB, so I will need to arrange the chips carefully to miss the US parts..
- IMG_3701.JPG (124.38 KiB) Viewed 4872 times
The problem is there, its pretty low down...
- side.jpg (46.28 KiB) Viewed 4872 times
- 1.jpg (61.39 KiB) Viewed 4872 times
- 2.jpg (32.14 KiB) Viewed 4872 times
Putting US upside down however gets pretty close to the drive, so higher up which is good...
- up2.jpg (39.47 KiB) Viewed 4872 times
- up1.jpg (63.07 KiB) Viewed 4872 times
The maybe slightly annoying thing here, is if the US header was a vertical one, we would have a vertical header on the MB, so US would *almost* plug right into the MB header.. Though the chances of it all lining up perfectly is pretty slim I bet.
- h1.jpg (75.36 KiB) Viewed 4872 times
Thinking ahead, it should be a cable, even though annoying, as if US header moves even 0.1mm its no longer going to line up with the MB header anymore. Cable is annoying, but solves alignment issues and a lot of headaches.
Getting the chips on the MB to "miss" all the stuff sticking up on US will be tricky enough..
