The TF330 is here
68030 + SDRAM + IDE
Re: The TF330 is here
alenppc wrote: 16 Dec 2018 23:11 Now it doesn't boot with any full 68030 (grey screen, tried two of them) but boots fine with EC030. Could it be something related to the MMU?
Not likely. I have the opposite issue anyways. The MMU CPUs work and the ones without them dont. I'll figure it out eventually. just strange.
The original pre_alpha firmware doesnt work?
alenppc
Post by alenppc »
It seems they all work fine with the EC ones only for the moment. The gold CPU works on and off randomly.
EDIT: The gold full cpu now booted with the firmware you just sent me but reports no fast ram. I put back the plastic EC one and it works fine, including ram. Very odd..
Ok. Experiment time.
Could everyone close the MMUDIS jumper and see if that makes a diff. Just want to eliminate the MMU from enquiries.
supaduper
Post by supaduper »
terriblefire wrote: 17 Dec 2018 09:14 Ok. Experiment time.
Sorry to be thick but where is that on the board
It’s one of these
Not sure which right now
alenppc
Post by alenppc »
Also, Viktor and Mark, can you try a gold cpu and see if there is any difference for you?
supaduper
Post by supaduper »
alenppc wrote: 17 Dec 2018 12:48 Also, Viktor and Mark, can you try a gold cpu and see if there is any difference for you?
Hi Alen
I have not got a Gold 50mhz cpu, but I have sent one of my TF330 builds to Steve so he can put one on it and compare results
**EDIT
I inputted " cpu fastrom" I jumpered both pins for the MMU and in sysinfo, open or jumpered it says" MMU in use"
am I doing something wrong lol
Its possible I screwed up the mmudis circuit. I’ll check later
alenppc
Post by alenppc »
Supaduper, that's a software issue. The CPU command cannot distinguish between EC030 and regular 030. So if you issue a CPU FASTROM on an EC030, the command will then report "68030 FASTROM" when queried, but you won't get the desired effect. For example, do a speed test on the IDE. Sysinfo will report about 2 mb/sec without fastrom and over 6.5 mb/sec with fastrom, and the entire system will be a lot more responsive if the fastrom actually works. There will be no change on an EC030.
I don't know how good Sysinfo is at distinguishing between the two CPUs, it could be the same as the CPU command.
supaduper
Post by supaduper »
alenppc wrote: 17 Dec 2018 16:22 Supaduper, that's a software issue. The CPU command cannot distinguish between EC030 and regular 030. So if you issue a CPU FASTROM on an EC030, the command will then report "68030 FASTROM" when queried, but you won't get the desired effect. For example, do a speed test on the IDE. Sysinfo will report about 2 mb/sec without fastrom and over 6.5 mb/sec with fastrom, and the entire system will be a lot more responsive if the fastrom actually works. There will be no change on an EC030.
Cheers Alen
Ok so I left the MMUDIS open(two pins furthest away from the TF330 connector) and did a` cpu fastrom` command and the did a `Drive speed` test in sysinfo on my DH0: part and the speed increase was there.
Then I did the same as above with the Jumper closed and the speed of the drive did not increase so the MMUDIS is working :)
Return to “TF330”
