terriblefire wrote: 15 Dec 2018 10:57
Yes probably. I didnt even think about this to be fair.
that's why we are here, bud! :P
Ok
actual feedback for now:
i had Samsung K4S561632J-UC75 (133Mhz) on, after flashing FW IDE blinked 1x followed by reboot then 1x IDE blinked again, nothing happened CD32 freezed. Was thinking card isn't happy with this RAM, swapped out to chips Stephen used, but got same pattern :roll: :?
Ok, this means to me RAM isn't the culprit, have burnt DiagROM, however it showed no errors on ram
(we need to contact Chucky and point him on bug in Automatic Fastram scan - it configs on a wrong address for some reason!!!)
well, then i wiggled TF330 and IDE.....and it booted!!
So yeah! My card is working, it boots even with WB 3.9 and it is quite comfortable to use,
i just need to solve some issues - as it doesn't boot here and there.. Will clean edge connector and swap out IDE cable (this is the same IDE ribbon i used on TF534, got also some issues there - IDE is working slow, maybe it is my flat ribbon in the end!)
Thank You Stephen, i am very happy with this result, also big thanks to Mark for his useful tips, this done my build faster,
these small issues with CD drive will be ironed out and rev.2 will be working excellent.. Living the dream! :thumbup: :cheers:
PS,
