There are my PAK68/3, PuPla/2, FRAK/2 with 64MB Fastram and a Panther/2 with ATI MACH64 and a NE2000 ISA Ethernet card.
Desktop Tower build -> https://forum.atari-home.de/index.php/t ... 367.0.html
The PAK68/3 (11/1993) Schematics are available at the Heise Website or on Heise c´t DVD Roms ...
Pak86/3 Tos Roms
Re: Pak86/3 Tos Roms
Sorry to have taken so long - not sure, lemme search my HDForgottenmyname wrote: Mon Dec 24, 2018 9:29 am Hi Darklord,
I don't suppose you have a schematic for this version of the Pak do you? Mine's not working so far but think it's a problem with my Atari, just wanted to rule it out.
and I'll get back to you.
PS Oh! Just noticed that Frank posted a link to the schematics.
Frank, you over-achiever you!frank.lukas wrote: Mon Dec 24, 2018 1:42 pm There are my PAK68/3, PuPla/2, FRAK/2 with 64MB Fastram and a Panther/2 with ATI MACH64 and a NE2000 ISA Ethernet card.
Truly, an awesome setup.
- frank.lukas
Very happy because the PAK68/3 run at 50Mhz and the speed is 200% of a Atari TT and with the MACH64 Graphic the speed is over 600%.
I bet! Even my PAK 68/3 in my STacy, only running at 40mhz beats a stock TT.frank.lukas wrote: Wed Dec 26, 2018 6:54 pm Very happy because the PAK68/3 run at 50Mhz and the speed is 200% of a Atari TT and with the MACH64 Graphic the speed is over 600%.
