Terriblefire Accelerators
SukkoPera
Re: Terriblefire Accelerators
Post by SukkoPera »
AIBB looks OK and all tests run fine.
I have just experienced the same issue I had on the A500+: every time I write to the CF, it gets totally corrupted.
SukkoPera
Post by SukkoPera »
OK, I reconfigured the expansion to 1 MB slow and the CF write issue seems gone.
I have tried the Memory Test in SysTest and with 1.5MB it fails with X's for all bits right at the start of the 0xC0000 range, weird.
SukkoPera wrote: Fri Nov 30, 2018 12:27 am OK, I reconfigured the expansion to 1 MB slow and the CF write issue seems gone.
Did you mean 0xD00000? Either way if alenppc isn’t seeing the issue I’m betting you have an issue like a short somewhere on the address bus.
SukkoPera
Post by SukkoPera »
I will check again tonight and post a pic of the failing test.
I don't think I have any issue on my machine, as the full 1.5MB range tests fine with the original 68000 CPU and 1 MB seems to work well with the TF card.
Some guy was mentioning in the PeteAU's expansion thread on EAB that to get a 100% working setup he had to use the latest bus JED but the previous RAM JED. Does that make any sense?
It will be a short on the TF530 if there is one
alenppc
Post by alenppc »
I will take another look at this also this weekend to see if I can reproduce it by booting Lotus II from WHDLoad. To be honest I haven't tested every game, but I've run Nemac IV, Frontier and a few others.
ICRY
Post by ICRY »
Hello I know you have a lot going on, so just wondering when the TF534 might be released for people to build.
Amazing work btw!
I'm planning to release them when I am sure i can get a set of gerbers that will work. I'll also sell what i have on eBay at the same time.
SukkoPera
Post by SukkoPera »
terriblefire wrote: Fri Nov 30, 2018 8:06 am
I've checked again and it fails in the 0xC00000-0xC7FFFF range, see pic (please ignore awful video quality):
Foto 01-12-18, 18 38 13.jpg (95.39 KiB) Viewed 3839 times
SukkoPera
Post by SukkoPera »
SukkoPera wrote: Fri Nov 30, 2018 9:07 am Some guy was mentioning in the PeteAU's expansion thread on EAB that to get a 100% working setup he had to use the latest bus JED but the previous RAM JED. Does that make any sense?
Should I try this?
