Sandord - progress
Re: Sandord - progress
sandord wrote: Thu Nov 08, 2018 3:33 pm Ugh, so I soldered half of the resistor arrays backwards. I somehow thought that they were serial networks but obviously they're parallel with a common ground. :x
Luckily I have a very good solder sucker since a few weeks!
Be careful with the sucker if it's manual, they can slip around and cause damage. I know from personal experience, so I mostly use wick now for de-soldering.
I would like to get a proper vacuum de-soldering tool though, maybe I can convince the wife for Xmas :)
I got one of the arrays in the wrong place (Wrong value for where it was supposed to be) and it came out fine.
sandord
Post by sandord »
rubber_jonnie wrote: Thu Nov 08, 2018 4:40 pm Be careful with the sucker if it's manual, they can slip around and cause damage. I know from personal experience, so I mostly use wick now for de-soldering.
Yeah, I'm happy I have the Engineering Solder Sucker TM now, which has a soft tip (short hose) so it won't scratch anything unless I drop the whole thing :D
sandord wrote: Wed Nov 07, 2018 9:46 pm
Header strips: how long do the leads need to be? I'm pretty sure the keyboard header should have about 8mm long leads, so default length doesn't work
The pins for the KB header are a lot longer than 8mm, If you have a donor board, then nick the KB header from there.
sandord
Post by sandord »
rubber_jonnie wrote: Thu Nov 08, 2018 4:44 pm The pins for the KB header are a lot longer than 8mm, If you have a donor board, then nick the KB header from there.
Good idea! :dualthumbup:
Also note that you will need to do a hack for the KB connector on the remake board, as it is short a pin!
sandord
Post by sandord »
rubber_jonnie wrote: Thu Nov 08, 2018 4:54 pm Also note that you will need to do a hack for the KB connector on the remake board, as it is short a pin!
Thanks for the reminder.
sandord
Post by sandord »
Current to do list:
- Add missing resistors (other parts are all there)
- Receive un-f*ck pcbs and solder them to the main board
- Apply all fixes
- Put chips in sockets
- Triple check everything
- Put hands over eyes
- Switch on
You've missed one step..... post pic of your STF running your fave ST game.
sandord
Post by sandord »
Forgottenmyname wrote: Fri Nov 09, 2018 10:57 pm You've missed one step..... post pic of your STF running your fave ST game.
How could I forget! :lol:
First let's hope I won't need to do much debugging.
sandord
Post by sandord »
I've hacked the keyboard connector:
With this, I've finished soldering all parts and headers. Still deliberately leaving out the three connects at the top right though.
Next: do remaining fixes, wait for un-f*ck boards.
Return to “ALPHA USER BUILDS”
