I now have most parts soldered to the board.
I'm leaving out the two connectors at the top right until I'm ready to test them. I have currently got two spacers screwed in their place so I'd rather keep those for now.
There are a few parts I'm currently not sure I have the right ones:
- Chrystal 32.0000 MHz: isn't this supposed to be 32.xxxx?
- Header strips: how long do the leads need to be? I'm pretty sure the keyboard header should have about 8mm long leads, so default length doesn't work there. But what about the RAM board connectors?
to make sure your IP is added into the firewall whitelist, thanks
Sandord - progress
Re: Sandord - progress
I used normal header pins for RAM & KB headers... but have to use proper Falcon RAM card for that as my blue card I think needs longer pins..
32mhz will work, just will show 99% speed. 32.08 is what I am going for now , (100%)
32.0000 MHz will work but you won’t get 100% scores in GEMBench. You can swap it for a 32.084988 MHz to get 100% scoressandord wrote: Wed Nov 07, 2018 9:46 pm I now have most parts soldered to the board.
For the RAM board header pins. If you have the Exxos SIMM ram board then you will need very long pins. An original Falcon board doesn’t need to be as long.
Having long header pins are good as you can also use them on the monitor and floppy un-f*ck boards
Just took a look at the height of headers. This is what I orderedIcky wrote: Wed Nov 07, 2018 10:01 pm32.0000 MHz will work but you won’t get 100% scores in GEMBench. You can swap it for a 32.084988 MHz to get 100% scoressandord wrote: Wed Nov 07, 2018 9:46 pm I now have most parts soldered to the board.
40 Pin 2.54mm 20mm Long Header Pins
Ah Exxos beat me to itexxos wrote: Wed Nov 07, 2018 9:48 pm I used normal header pins for RAM & KB headers... but have to use proper Falcon RAM card for that as my blue card I think needs longer pins..
The brown ones seem to be from Preci-dipsandord wrote: Tue Nov 06, 2018 3:44 pm Ah, so I got it the other way around. Funny, the brown one seems to be of much higher quality.
http://www.precidip.com/en/Products/PGA ... 4-008.html
Ingo
Ah, thanks. I have no idea why Farnell decided to put that one in my package while I ordered 3M sockets only.IngoQ wrote: Thu Nov 08, 2018 11:50 am The brown ones seem to be from Preci-dip
Maybe they thought the'll do you a favor
But more likley the picking guy just had a serious hangover...
Ingo
I'm pretty sure that was the reason yesIngoQ wrote: Thu Nov 08, 2018 12:59 pm But more likley the picking guy just had a serious hangover...![]()
I used it for the blitter, which I'm probably not going to install anyway.
Ugh, so I soldered half of the resistor arrays backwards. I somehow thought that they were serial networks but obviously they're parallel with a common ground.
Luckily I have a very good solder sucker since a few weeks!
