Check if your IP is banned
viewtopic.php?t=7286
The server is under a massive attack which started yesterday morning.
Unfortunately I am not at home on weekends to keep a eye on it all.
So if we go down, I will not be able to fix it until Sunday night. Fingers crossed we stay up!
I have also had to block and ban anything with HTTP1.x protocol.
So make sure you are using HTTP2 otherwise you will get banned!
~exxos~
~exxos~
Sandord - progress
Re: Sandord - progress
One fix I do is to cut the legs off of a donor chip and solder them on top of the broken ones, giving you legs again.
Nice, I think I'll do this.Forgottenmyname wrote: Sun Oct 28, 2018 8:33 pm One fix I do is to cut the legs off of a donor chip and solder them on top of the broken ones, giving you legs again.
To protect the patches that will be on the bottom of the board, I put these spacers on the bottom. I actually have two more spacers mounted to the serial/printer port holes but they're not on the picture.
Alright, I've most finished the shopping list for the remaining parts. I'm just struggling a bit finding the right crystal (I can use the 2.xx one from the ST though, right?) and I don't see where to put the SIP9 caps...
sandord wrote: Mon Oct 29, 2018 11:23 pm Alright, I've most finished the shopping list for the remaining parts. I'm just struggling a bit finding the right crystal (I can use the 2.xx one from the ST though, right?) and I don't see where to put the SIP9 caps...
Yeah, assume you mean the MFP one ? I am going to stock them in my store at some point..
SIP 9 caps ? There are SIL resistors.. mostly around the CPU area...
have a look at my image... https://www.exxosforum.co.uk/forum/viewt ... =64&t=1268
Yeah, the one near the MFP. The one from the shifter shield isn't going on the remake board because it would need an additional circuit, so I have to order an integrated one, right?exxos wrote: Mon Oct 29, 2018 11:29 pm Yeah, assume you mean the MFP one ? I am going to stock them in my store at some point..
Silly me, I got mislead by the colour and the 105-style coding. I meant the one sitting below the WD1772 but I see that's just a resistor pack.exxos wrote: Mon Oct 29, 2018 11:29 pm SIP 9 caps ? There are SIL resistors.. mostly around the CPU area...
Yeah you need a 32mhz oscillator 5volt.
Got myself that Weller after all, really glad with it. Heats up from 18 to 370C in 47 seconds. The higher power (50% more) is also very helpful.
Did you get the password protected onesandord wrote: Wed Oct 31, 2018 10:15 pm Got myself that Weller after all, really glad with it. Heats up from 18 to 370C in 47 seconds. The higher power (50% more) is also very helpful.
