Sandord - progress
sandord
Re: Sandord - progress
Post by sandord »
exxos wrote: Sun Oct 28, 2018 12:19 am https://uk.farnell.com/tenma/21-10115-u ... dp/2064549
That's the one I use..
Can you give me the model name? The site says it's down...
sandord wrote: Sun Oct 28, 2018 12:21 am
Its in the link...
sandord
Post by sandord »
Thanks. I looked around a little more and I'm kind of intrigued by this thing: https://www.aoyue.eu/aoyue-int968-smd-r ... ction.html
I guess I could keep looking for ages but rather ask myself: do I need those features? Just keep it simple I guess. But tempting...
Wattage is a bit low for soldering... That's a smt rework station..
sandord
Post by sandord »
Forgottenmyname wrote: Sat Oct 27, 2018 7:50 pm Psychic ordering perhaps :D.
I'm sending positivie psychic waves..... exxos..... please send me a .....
I'm sure I will find replacement chips in the mail even before I know I've fried them during desoldering from my donor ST :D
sandord
Post by sandord »
So, I FINALLY managed to remove all parts from my donor ST. At least, the ones I need for the remake ;)
But djeez was it hard. Especially the last 68B50, I think it took my literally 2 hours to get it off. And I broke two legs (the slim end) in the process :oops:
Yes, I used a very good solder sucker, flux, wick. For some chips I had to repeat like 20 times before finally being able to get it off. Maybe this ST was assembled with magic glue or something :?
Anyway, I've got the parts now. But hopefully I didn't fry any of them, since I had so much work getting them off of the pcb.
By the way, those broken pins, I'll just stick a lead in the socket and then solder it to the remains of the pin on the chip.
Solder the acia to the board ..
sandord
Post by sandord »
exxos wrote: Sun Oct 28, 2018 8:15 pm Solder the acia to the board ..
I might have fried it during desoldering. I have no proof but I'm just not sure it still works.
Well, I'm not looking forward to desoldering anything for a while so I'd rather have it sit in a socket ;)
Return to “ALPHA USER BUILDS”
