Sandord - progress
Re: Sandord - progress
PaulJ wrote: Sat Nov 10, 2018 5:27 pm I'm using the ultra satan 19 pin plug which is vertical in relation to the 19 pin board connector. Is the 1772 daughter card stretching beyond the connector to interfere with the ultra satan plug in connector?
I think you won't be able to plug in the vertical UltraSatan:
Icky wrote: Sat Nov 10, 2018 4:59 pm Yep - I'm up for BETA board
We not done breaking the alpha yet ;)
PaulJ
Post by PaulJ »
exxos wrote: Sat Nov 10, 2018 5:58 pm
Maybe for Xmas we will all chip in and get ya a shinny new ruler!! ;)
sandord
Post by sandord »
I guess ya'll know what I'll be doing next ;-)
I'll be out of town for a few days so that won't be before tuesday or something though.
Btw, I was wondering whether those sharp spikes on the sides are in the design or a production 'feature'?
sandord wrote: Wed Nov 14, 2018 7:59 pm I guess ya'll know what I'll be doing next ;-)
They are a production feature. It’s where they are held onto the bigger manufacturing board ie the snap tag left after milling the board outline.
sandord
Post by sandord »
Now, am I supposed to listen to this while soldering the 1772 buffer prototype?
while
sandord wrote: Fri Nov 23, 2018 10:12 pm Now, am I supposed to listen to this while soldering the 1772 buffer prototype?
Someone finally noticed that then :lol:
It was what I was listening to while I was designing the board... and actually has some very fitting lyrics to the board as well....
sandord
Post by sandord »
exxos wrote: Fri Nov 23, 2018 10:23 pm Someone finally noticed that then :lol:
Well, I enjoyed it :D I've been listening to everything YouTube put up after that. Actually, it was 90% Radio Head. It makes nice soldering music, calming me down before I explode when something goes wrong with the soldering :lol:
Anyway, here's the un-f*ck boards in place, including the 1772 buffer board.
sandord
Post by sandord »
Did some more fixes today, now about half way of the work.
Jumper pads                     Y
Reset fix                       Y
HSYNC fix                       Y
BR pull up fix                  Y
5x resistor fix                 Y
VIDEO socket fix                Y
16MHz buffer fix                Y
GLUE Dataline fix               Y
MFP pull up fix                 N
RAM RW fix                      N
KB connector missing gnd pin8   Y
1772 IRQ typo fix               Y
KB resistor fix                 N
ACIA databus fix                N
Floppy pull up fix              N
Added buffer to MONO output.    N
Fixed common name "RD" between
 1772 & 232 circult             Y
Changed reset capacitor to 47uF
 to increase reset time as was
 causing issues when booting up.?
Changed 8 pin XO to 14 pin.     N
PLANNED UPDATE for 1772
 BUS SHORT FIX                  N
PARALLEL PORT FIX               N
VIDEO BRIGHTNESS FIX            Y
sandord
Post by sandord »
By the way, the green wire in the last picture is a correction for a mistake I made. I pulled a via there :cussing: :pullhair:
But luckily, I could reconstruct it this way :) Phew.
Return to “ALPHA USER BUILDS”
