DMA port "update" ideas..
Re: DMA port "update" ideas..
exxos wrote: Mon Oct 22, 2018 11:40 pm
Icky wrote: Mon Oct 22, 2018 11:34 pm Nope its booted - The 16MHz needed to be buffered so I took it from the 16MHZ_BUFFERED_1 that was spare on IC900 pin 12
oh sweet! benchmark time then ;)
Spoke to soon its temperamental. Went to put in the HDD and it did not boot. No signal this time.
Put it back to 8MHz and its working again.
Icky wrote: Mon Oct 22, 2018 11:44 pm Spoke to soon its temperamental. Went to put in the HDD and it did not boot. No signal this time.
Assume you going through a 33R resistor to the DMA clock pin ?
exxos wrote: Mon Oct 22, 2018 11:48 pm
You assume right :)
It does seem to be temperamental on 16MHz
Icky wrote: Tue Oct 23, 2018 12:00 am It does seem to be temperamental on 16MHz
Could be interfacing issues to the MMU, or the DMA might not just cope with it. Up the voltage a bit, see if it helps :P
exxos wrote: Tue Oct 23, 2018 12:04 am
Will take a better look tomorrow.
Icky wrote: Tue Oct 23, 2018 12:10 am
Yep got it stable with a bit more juice :)
However although its running at 16MHz the Gigafile is not recognised @ 16MHz. Drop back down to 8MHz and it sees it
Icky wrote: Tue Oct 23, 2018 6:55 pm Yep got it stable with a bit more juice :)
Does the floppy still work ?
exxos wrote: Tue Oct 23, 2018 7:07 pm
Yes the floppy works fine.
EDIT: @16MHz
Icky wrote: Tue Oct 23, 2018 7:11 pm Yes the floppy works fine.
EDIT: @16MHz
If you can format a floppy fully, it will test the DMA out at the higher speeds better...
Assume gigafile doesn't like the faster port speed :(
exxos wrote: Tue Oct 23, 2018 7:13 pm If you can format a floppy fully, it will test the DMA out at the higher speeds better...
I'll give that a go shortly - need food first :)
