16MHZ OPTIONAL FIX
Got the wire a little too hot here and melted back the insulation further than I'd like, but nothing risky is nearby, so it'll do.
(Yes, I did just cut that resistor off at the board instead of desolder it.)
:o)
:o)
derkom - Progress
derkom
Re: derkom - Progress
derkom
Quick question about the GLUE DATALINE FIX...
In step 1, it says, "Cut D0 & D1 tracks on the bottom of the PCB" and the red indicator covers two tracks in the picture:
Is it correct to cut both tracks covered by the red line, not just the yellow track? Since the instructions say to cut D0 and D1, and the non-yellow track goes to D0, I think I know the answer, but I want to double check with you guys before I cut. :?
Yes, cut both tracks :)
If you zoom the image, you can see D0 & D1 on the IC holes.
derkom
Yep, I did see the labels. Just wanted to be ultra-sure before cutting. Thanks! :)exxos wrote: 14 Oct 2018 11:49 Yes, cut both tracks :)
Always a good plan! :)
derkom
So, life got in the way and kept me away from this project for a long time. I've finally picked it up again and made some progress, although I'm not getting video (more on this later).
For now, various pullups and the GLUE dataline patch (don't ask about the bits in the corner):
derkom
MFP fix, keyboard resistor fix, ACIA dataline fix ...
derkom
RAM RW fix ...
derkom
1772 IRQ typo fix ...
derkom
Floppy pullups fix ...
